Slow speed after political debate last night....
- Slow speed after political debate last night....
03-04-2015 10:04 AM
.... which may be coincidence. Since joining in December 2014 I have had no speed problems at all, normally seeing over 8 mbps on a regular basis.
Last night things started to crawl so tried the BTW speedtest which showed 1.79 UL, shortly after speed appeared to slow even further and the BTW site wouldn't load at all, later it would load but on selecting test it would return :-
"System is busy, try again later"
BTW site is still returning this message when I try to test this morning although speed seems OK for the internet and we watched a Netflix TV episode last night which was fine.
Did the line noise test which showed a clean line but didn't have a filter readily to hand to try the test socket out.
Any ideas why?
Any ideas why?
Message 1 of 9
(1,247 Views)
8 REPLIES 8
Re: Slow speed after political debate last night....
03-04-2015 11:25 AM
Message 2 of 9
(728 Views)
03-04-2015 12:21 PM
Thanks Tony.
Opened a chat link with PN support this morning, suggestion that it was browser cache seemed true as I stopped Firefox, opened IE and BTW workked. Logged back in 1/2 hour ago and speed showed 0mbps on BTW but 0.89 on different. bb speed check site. Closed laptop and restarted. BTW showing 0 dl speed, broadbandspeedcheckker showing 8.36 dl, 0.7 ul. I'm tending to believe BBSC rather than BTW as internet APPEARS to be OK, tried a youtube vid which didn't lag or buffer. Here are my current TN router stats. As I say, seems to be working OK. I'm running a dell laptop with 8gb ram, intel core i7 processor and loads of spare disc space so it "shouldn't" be my system
DSL Connection
Link Information
Uptime: 0 days, 14:09:41
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 910 / 11,043
Data Transferred (Sent/Received) [MB/GB]: 199.66 / 5.43
Internet
Connection Information
Link Status: IPv4 connected
IPv6 disconnected
Uptime: 0 days, 7:48:25
Data Transferred (Sent/Received) [MB/GB]: 147.07 / 4.80
Username: <snip>
Password: ********
Remember Password: Yes
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 146.90.170.233
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
TCP/IPv6 Settings
IPv6 State: Disabled
Download speed now 3.99
jim:green username removed mod:end
DSL Connection
Link Information
Internet
IPv6 disconnected
Username: <snip>
Password: ********
TCP/IPv4 Settings
IPv4 State: Enabled
TCP/IPv6 Settings
Message 3 of 9
(728 Views)
03-04-2015 12:24 PM
Quote from: plusnettony I'm not aware of any problems, but I'll keep an eye on any reports. The BTw test seems to be working ok now from here.
hi tony, please check this issue related to broken iwf proxies.
http://community.plus.net/forum/index.php/topic,138250.new.html#new
Message 4 of 9
(728 Views)
03-04-2015 12:26 PM
Here's my event log from the TN router this morning
Info Apr 3 12:19:14 CONFIGURATION mbus igd sync successfull
Info Apr 3 12:19:11 CONFIGURATION mbus atomic sync successful
Info Apr 3 12:18:11 LOGIN wireless station [10:08:b1:b9:2e:53] can't get authorized.
Info Apr 3 12:17:06 LOGIN User admin logged in on [HTTP] (from 192.168.1.66)
Info Apr 3 12:13:26 SNTP Synchronised again to server: 212.159.13.50
Error Apr 3 12:09:35 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 80.201.108.126 Dst ip: 146.90.170.233 Type: Destination Unreachable Code: Host Unreacheable
Info Apr 3 11:58:10 LOGIN User admin logged in on [HTTP] (from 192.168.1.66)
Error Apr 3 11:42:21 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 81.82.216.84 Dst ip: 146.90.170.233 Type: Destination Unreachable Code: Port Unreacheable
Error Apr 3 11:39:17 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 2.51.25.237 Dst ip: 146.90.170.233 Type: Destination Unreachable Code: Host Unreacheable
Info Apr 3 11:18:11 LOGIN wireless station [08:d8:33:9d:3d:35] can't get authorized.
Info Apr 3 11:13:25 SNTP Synchronised to server: 212.159.13.50
Info Apr 3 10:13:25 SNTP Synchronised to server: 212.159.13.49
Info Apr 3 10:06:49 LOGIN User admin logged in on [HTTP] (from 192.168.1.66)
Error Apr 3 09:52:51 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 37.145.251.175 Dst ip: 146.90.170.233 Type: Destination Unreachable Code: Host Unreacheable
Info Apr 3 09:13:25 SNTP Synchronised again to server: 212.159.13.50
Info Apr 3 08:13:25 SNTP Synchronised again to server: 212.159.13.50
Info Apr 3 07:13:25 SNTP Synchronised to server: 212.159.13.50
Error Apr 3 06:52:11 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 219.158.19.46 Dst ip: 146.90.170.233 Type: Time Exceeded Code: Time to Live exceeded in Transit
Info Apr 3 06:13:46 SNTP Synchronised again to server: 212.159.13.49
Info Apr 3 05:13:46 SNTP Synchronised to server: 212.159.13.49
Warning Apr 3 04:49:01 IDS scan parser : tcp port scan: 216.58.210.10 scanned at least 10 ports at 146.90.170.233. (1 of 1) : 216.58.210.10 146.90.170.233 40 58 TCP 443->57063 [...R..] seq 3179125988 ack 0 win 0
Info Apr 3 04:31:40 CONFIGURATION saved by TR69
Warning Apr 3 04:30:59 PPP link up (Internet) [146.90.170.233]
Info Apr 3 04:30:59 FIREWALL event (1 of 2): deleted rules
Info Apr 3 04:30:59 PPP CHAP Receive success (Internet)
Info Apr 3 04:30:59 PPP CHAP Receive challenge from rhost PTW-AG03 (Internet)
Info Apr 3 04:30:57 PPP CHAP Receive challenge from rhost bras-red5.nt-b (Internet)
Info Apr 3 04:30:44 FIREWALL event (1 of 1): modified rules
Info Apr 3 04:30:44 FIREWALL event (1 of 1): created rules
Warning Apr 3 04:30:44 PPP link down (Internet) [146.199.207.242]
Info Apr 3 04:13:46 SNTP Synchronised again to server: 212.159.13.50
Info Apr 3 03:13:46 SNTP Synchronised to server: 212.159.13.50
Info Apr 3 03:08:32 LOGIN wireless station [08:d8:33:9d:3d:35] can't get authorized.
Info Apr 3 02:13:45 SNTP Synchronised again to server: 212.159.13.49
Info Apr 3 01:13:45 SNTP Synchronised to server: 212.159.13.49
Message 5 of 9
(728 Views)
03-04-2015 3:42 PM
Message 6 of 9
(728 Views)
03-04-2015 4:59 PM
it isnt, I just wanted to grab your attention
sorry to the OP for the disruption, mods feel free to delete my posts.
Message 7 of 9
(728 Views)
03-04-2015 5:06 PM
Message 8 of 9
(728 Views)
03-04-2015 8:12 PM
BTW still reporting 0mbps DL,
Broadbandspeedchecker showing 5.02
Internet working fine....I know which one I believe
Message 9 of 9
(728 Views)
