Slow internet
- Slow internet
- « Previous
- Next »
Re: Slow internet
24-09-2014 2:34 PM
Quote from: jelv Have you checked your local council's BDUK plans to see if there is anything in the pipeline?
If something is in the pipeline it might have some information here: http://www.superfast-openreach.co.uk/where-and-when/#
Re: Slow internet
24-09-2014 2:36 PM
Quote from: Zekemoore There's no way you're going to convince me that 150kB/s is good .
I didn't say 150kB/s was good - I said it was good for your line.
Re: Slow internet
24-09-2014 3:27 PM
BT BROADBAND AVAILABILITY CHECKER attached to this post
Re: Slow internet
24-09-2014 3:34 PM
i would advise you upgrade to FTTC if you want faster speeds.
ps. your signature is childish and immature.
Re: Slow internet
24-09-2014 3:35 PM
Have you access to another modem/router to try?
Re: Slow internet
24-09-2014 3:41 PM
At the moment i don't have access to another router , though i will try and get another one .
Can anyone confirm that the internet light on the Technicolor modem is supposed to be a solid green light ?
Re: Slow internet
24-09-2014 3:42 PM
the internet light will flash during activity.
Re: Slow internet
24-09-2014 3:54 PM
Quote from: Townman If I can trust the router stats - attenuation of 69.5dB suggests you should get no ADSL whatsoever!!!
All advice given has been predicated on the above.
BT estimates are just that estimates, not an assurance.
What does this report - http://www.kitz.co.uk/adsl/adslchecker.php ? In particular the line length. If it is different to 5km then may be there is something to be explored. However other than your opinion and the BT estimate, there is nothing to suggest that line is behaving otherwise than correct.
As for your sig, you have no information about the age of the spectrum of forum members on which to make the claims about the age of 60% of members. Age of members has no real bearing on matters, other than the older ones usually have a lot more experience than the younger ones, albeit we might just be not quite so young enough to know everything about everything.
- « Previous
- Next »
