Slow internet on peak hours
- Slow internet on peak hours
- « Previous
- 1
- 2
- Next »
Re: Slow internet on peak hours
27-10-2018 9:15 PM
I will try to get another router but I do not have anyone at hand.
Thanks for the check up.
27-10-2018 9:29 PM
Is this still true?
Traffic Prioritisation is not applied to Unlimited, Unlimited Fibre or Unlimited Fibre Extra.
Because I have Unlimited but I have a strong feeling that some Prioritisation is in place because I have seen behaviours which are compatible with it.
28-10-2018 8:16 AM
I have tested again just now, 8:10 Sunday morning, off peak I guess
Down Up Latency
14.23 0.59 163.38
16.09 0.66 164
14.20 0.67 159
Download speedachieved during the test was - 14.2 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.78 Mbps
Upload speed achieved during the test was - 0.67Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
And this are the router stats. I am concern about the error and loss figures, are they not a bit alarming?
Link Information
Uptime: 0 days, 17:53:21
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 828 / 16,752
Data Transferred (Sent/Received) [GB/GB]: 2.00 / 5.08
Output Power (Up/Down) [dBm]: 12.2 / 20.9
Line Attenuation (Up/Down) [dB]: 14.2 / 27.5
SN Margin (Up/Down) [dB]: 7.8 / 6.1
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 8 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 437 / 0
FEC Errors (Up/Down): 15,069 / 139,971
CRC Errors (Up/Down): 17 / 266
HEC Errors (Up/Down): 6 / 5,852
28-10-2018 8:37 AM - edited 28-10-2018 8:40 AM
@josemaria Thanks for a definite off-peak test.
The BT tests show things are roughly where they should be - the upload looks a bit low, but I've always found that to be the case whenever I've run the test, so to be honest I wouldn't place much reliance on it.
Out of curiousity, where do you get the block of figures headed Down, Up, Latency? Because the middle 'Down' of 16.09 looks suspicious.
With regard to the error figures, as I have said, sorry, can't really comment because I don't know enough, but based on comments I had when experiencing connection issues, I would get them checked.
Any luck with a second router?
28-10-2018 9:12 AM
I get those up down latency running the BT speed test 3 times myself.
Thanks for you help.
28-10-2018 9:52 AM
OK, that explains the figures, but the one I mentioned is a 'rogue'.
29-10-2018 12:56 PM
@josemaria wrote:
Is this still true?
This is still true.
I've pushed the fault report back to our suppliers for further investigation, although I imagine at this point they'll likely come back asking us to book an engineer visit. We'll keep you updated via the ticket on the account regarding this.
29-10-2018 1:13 PM
Great, thanks
- « Previous
- 1
- 2
- Next »
