Slow connection
- Re: Slow connection
Slow connection
14-12-2015 5:14 PM
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 31 days, 8:43:24
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.263 / 20.807
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,99
Output Power (Up/Down) [dBm]: 12,5 / 0,0
Line Attenuation (Up/Down) [dB]: 11,2 / 21,5
SN Margin (Up/Down) [dB]: 6,2 / 3,3
Loss of Link (Remote): -
Error Seconds (Local/Remote): 15.250 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 526 / 19.485
HEC Errors (Up/Down):
Re: Slow connection
14-12-2015 6:03 PM
Re: Slow connection
14-12-2015 7:43 PM
Quote from: sparkalfa ... should I report a fault?
I say Yes. Before doing that you might want to check those error figures, see if they're still clocking up. Also the normal on site checks, different filter, plugged into master socket with everything else disconnected etc.
Re: Slow connection
14-12-2015 8:03 PM
There doesn't appear to be anything wrong with your ADSL connection to the exchange. Perhaps the exchange is busier with lots of people being home for the holidays or something like that.
Edit: sigh, missing don't
Re: Slow connection
15-12-2015 8:13 AM
I will try a reboot and then test again BT speed tester is reporting the same speeds and says may profile is 18Mbts and the acceptable range is 4 to 21!!!!
Oddly I have noticed that since I've had the slower download speeds my upload speeds have gone up from 0.6 to 1.2 is that significant?
Re: Slow connection
15-12-2015 9:06 AM
"Slow" when and by what measure? Time of day and service used to measure DATA speed will have a marked bearing on the reported figures. Can you please do a full BTw speed test, further diagnostics and report the PlusNET current speed - see link below. Do not restart the router for these tests.
Which router are you using? If not the 2704n then setting up a TBB BQM will be helpful. If you have a dynamic IP you will need to re-establish it after each new PPP session, but it will show clearly if there is congestion in the exchange.
Re: Slow connection
15-12-2015 7:37 PM
It's slow I think because for the last 6 or so months I have Been getting 17mbs consistently now It is only low 12's
Plusnet results:
Estimated line speed:
18Mb (This may vary between 16.5Mb and 20.5Mb) - Checked on 2015-10-06 09:10:56
Current line speed:
18.3 Mb
I will do a BT wholesale test shortly and post results
Just for info there are no pc's I. The house it's all Mac if that makes a difference
Re: Slow connection
15-12-2015 8:09 PM
Re: Slow connection
15-12-2015 10:13 PM
1. Best Effort Test: -provides background information.
Download Speed
12.73 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 12.73 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 18.36 Mbps
Upload Speed
0.98 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.98Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Re: Slow connection
15-12-2015 10:19 PM
Re: Slow connection
16-12-2015 12:12 AM
