Slow broadband and occasional drops
- Slow broadband and occasional drops
Re: Slow broadband and occasional drops
17-12-2019 5:22 AM
Thanks but I never use the phone so there's no pattern. I just noticed it was disconnecting the internet while I was running through all the tests and checking cables and filters again.
There's no particular device that triggers the disconnections. It just happens randomly. The broadband light on the modem starts flashing like crazy and the internet light goes off dropping the connection. It takes a minute or so to reconnect.
17-12-2019 5:37 AM
17-12-2019 12:46 PM
"Thanks but I never use the phone so there's no pattern."
You might not use the phone, but if you do not have a handset connected to the line, you do not know what unsolicited inbound calls the line might be receiving. There are conditions in which any phone activity can cause ADSL to drop.
17-12-2019 1:03 PM - edited 17-12-2019 1:06 PM
That's why I said there was no pattern.
And thanks for your reply.
I wish someone from Plusnet would reply too. 😞
17-12-2019 6:15 PM
Hey @Mjan,
Sorry to hear this issue is cropping up again, to for clarity please get connected into your test socket and monitor the connection for 24 hours or so. Once you've gone ahead with that step please get back to us here and we can raise a fault to our suppliers for further investigation.
Thanks.
17-12-2019 6:49 PM
My modem and phone have been connected to the test socket for months now. Last time the openreach engineer came over to change the drop line he just left it connected like that and said it was ok.
18-12-2019 6:20 PM
Hi @Mjan,
Thank you for confirming that and I'm sorry that you're still experiencing connection problems. I've arranged an engineer visit for you between 1pm and 6pm tomorrow (the 19th of December) and have confirmed this on the fault ticket here. Our faults team will contact you once we've received an update from our suppliers after the visit. Please get back in touch on here if you need us to rearrange this appointment or if there's anything else that you'd like to discuss in the meantime.
19-12-2019 3:59 PM
The openreach engineer just came and tested the line. He couldn't find any problems with his tests from my socket and seemed confused as to why I have so many disconnections.
He replaced my socket with a new one with a built in filter and said maybe the problem is with the router or at the exchange. He said he was going to continue tests outside and I guess he has been because I got disconnected again so, I'm assuming, it's him (I hope).
It's a mystery, the other engineer, a few months ago, also couldn't find a fault, and changed the drop line into the property.
At least the problem isn't with my internal lines.
We'll see what the report says... It's just so frustrating no-one can find what the issue is.
21-12-2019 12:10 PM
Thanks for getting back to us @Mjan.
From what we can see it's looking good so far as per the below graph.
I'd recommend monitoring the connection to see if the drops reoccur. If they do let us know and we'll get the fault escalated for you.
21-12-2019 5:57 PM
27-12-2019 2:10 AM
Yesterday, Boxing day, between 10 and 11:30 pm there was 3 disconnections, at least. It kicked me and my daughter off our online games.
It's a shame because it's been working fine since the engineer came over last week. And we have been home a lot so no changes in use or any other electrical equipment used in our household.
We abandoned gaming for the evening but I think we may have had more disconnections after that while using our phones.
Could you have a look and provide another graph, please?
on 28-12-2019 4:19 PM - last edited on 29-12-2019 8:48 AM by dvorak
I'm sorry to see you're continuing to experience connection problems. I've tested your line today and while the tests aren't showing any causes for this, we can definitely see the drops and your speeds would suffer as a result.
Looking back through your fault history, I can see we've arranged two engineers in total and the work carried out was to renew the drop-wire coming into your property and renew your master socket.
While there are additional quality checks I'd like to see carried out for example to check the line all the way to the exchange, it'd be a good idea to try another router first, so I've sent you a replacement now, which we'll get to you as soon as we can.
I'm taking this on personally moving forward so I'll follow things up with you once you've received your new router.
If you're interested I've attached a copy of our testing below:
xDSL Status Check | |||
Circuit ID: | CB******* | Service ID: | [redacted] |
Telephone NO.: | NA | Test Executed On: | 28-12-2019 16:04:36 |
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 8.1 | 17.5 |
SNR Margin: | 17.0 | 15.3 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 1474937 | 6304350 |
Speed: | 522 | 13119 |
Maximum Stable Rate (KBPS): | 18176 | Fault Threshold Rate (KBPS): | 14541 | ||
Mean Time Between Retrains (Seconds): | 43081 | Mean Time Between Errors Upstream (Seconds): | 14360 | ||
Indicative Line Quality: | G | Mean Time Between Errors Downstream (Seconds): | 545 | ||
Custom Thresholds | |||||
MTBR_RED: | MTBE_RED: | ||||
MTBR_GREEN: | MTBE_GREEN: |
Moderators Note: Circuit number removed at request of poster
28-12-2019 4:44 PM
It's very odd how the connection stayed on for 6 days but then, when the disconnections start, they come back with a vengeance.
I'll let you know when the router arrives.
28-12-2019 5:23 PM
No problem @Mjan Yeah it's really odd and I'm hoping the new router fixes this for you, but if not I'll arrange another engineer and get this escalated with Openreach. In the meantime I hope you have a good New Year next week.
02-01-2020 11:53 AM
Happy new year @Mjan It looks like you've received your router on the 31st. Assuming I'm right, how have things been since then? If you've not received your new router quite yet, you hopefully should do soon.
