Slow Web Browsing
- Slow Web Browsing
Slow Web Browsing
21-01-2009 11:50 PM
Hi
My Broadband appears to be slow. I've noticed the drop in recent months.
Browsing and Downloading appear to be pretty slow. This week I've started see'ing problems with gaming (On Line with PS3)
Your DSL connection rate: 5824 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 5000 kbps
Actual IP throughput achieved during the test was - 532 kbps
Router Setup:
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
Corrected Blocks: 28
Uncorrected Blocks: 2185
SNR Margin: 11
Loop Att: 37
James
Router Setup:
SNR Margin: 11
Loop Att: 37
James
Message 1 of 3
(785 Views)
2 REPLIES 2
Re: Slow Web Browsing
22-01-2009 12:43 AM
Hi James,
i noticed a similar problem to yours....
are you connecting to your router via wireless adapter or network cable
if wireless run a speedtest using a network cable
as i found a fault with the wifi antenna on my laptop which was causing the problem
looking at your dsl downstream you should be getting a healthy 5mb+
cheers
kw
ACS
cheers
kw
ACS
Message 2 of 3
(284 Views)
22-01-2009 10:41 AM
Hi James,
That's a bit weird and there's nothing obvious that I can see that would be wrong with your connection to give those speeds. There's no apparent errors on the connection and your sync (connection) speeds are fine.
How does your PC connect to your router?
Message 3 of 3
(284 Views)
