Slow Speed
pierre_pierre
Re: Slow Speed
pierre_pierre
Re: Slow Speed
looking at this page http://www.satcure.co.uk/accs/page22.htm#modlead Item 430-00312 its just a modem type lead to connect to the filter (phone) socket, perhaps Wattsy could advise what type of plug is on the other end of the lead, then just a cheap lead and do away with the extra adaptor
wattsy
Re: Slow Speed
  Hiya
  Had an hospital appointment this morning so couldn't get photos done til now. If I could aviod having to lift the carpet for a new lead I rather but
  it's not a great lose if I have to!!!!!!!
  Here are the photos you requested
  Regards
HPsauce
Re: Slow Speed
Never seen one like that before, but the good point is that you only need to connect 2 and 5. Presumably the terminals are clearly labelled - can't see that in the picture.
(and you should use "proper" twisted pair phone cable, not that awful flat stuff)
Anotherone
Champion
Fixes: 21
Re: Slow Speed
Hi Wattsy,
Even though the photos aren't too clear, they are IDC terminals (Insulation Displacement Connector). Hopefully they are still OK if you've been at them with your screwdriver  Lips_are_sealed
You need a little tool from B&Q, maybe PCworld, any telephony shop, Maplins etc. There are some very expensive ones around called Krone tools, but there are plastic ones available eg B&Q 40p or so. You don't need an expensive one. The generic name would be an IDC Insertion Tool.
In the meantime you can plug that 'Tamar' filter in at "the socket where you plug your sky in", taking stats as I explained yesterday. Then, you may as well powerdown the router for an hour say, and powerup  before mid afternoon say, to recover that sync speed. I won't be able to post until later on today, so I'm hoping Pierre will be able to find you a few pictures of how to use the IDC Insertion tool - he' so good at finding info, and pictures like that Smiley But in any event, there is no immediate rush for that.
@HP this is the phone lead from the sky receiver, there's no real choice about the cable apart from which it'll be filtered.
wattsy
Re: Slow Speed
  Thanks for that information anotherone
Thses are the results for this morning, the 'Tamar' filter has been plugged into the extension socket (where sky adapter will go) since last night.
System Up Time 01:59:51
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 6992 7616 0 320 597 01:59:28
LAN 100M/Full 8233 14654 0 643 420 01:59:47
ADSL Link Downstream Upstream
Connection Speed 5024 kbps 448 kbps
Line Attenuation 36 db 8 db
Noise Margin 8 db 26 db
Regards Wattsy
HPsauce
Re: Slow Speed
Quote from: Anotherone
Understood that, but thought it had been extended (under the carpet?). Obviously the captive lead on the receiver isn't changeable.
Anotherone
Champion
Fixes: 21
Re: Slow Speed
Probably have to go into an RJ11 HP.
Wattsy those stats are starting to look better, good luck with finding the tool, I've PM'd Pierre about pics. Speak to you later.
pierre_pierre
Re: Slow Speed
you can use one of these on the end of the wire instead of the adaptor, you just put the wire into the end using again just 2 and 5 this from Maplins only £3.29 Order Code: BD41U the black bit is the tool,  then you dont need the "damaged" adaptor, Easy for me BUT
pierre_pierre
Re: Slow Speed
Oh well I was commanded to find the instruction, here goes  http://web.ukonline.co.uk/freshwater/wiring/socketwiring.htm
wattsy
Re: Slow Speed
        Hiya
These results taken 5pm, router been disconnected throughout the afternoon
System Up Time 00:01:40
WAN PPPoA 364 651 0 798 3302 00:01:18
LAN 100M/Full 680 716 0 3518 1185 00:01:36
Connection Speed 4896 kbps 448 kbps
Noise Margin 8 db 24 db
These results are with the sky adapter plugged through the tamar filter
System Up Time 00:50:06
WAN PPPoA 2208 2507 0 166 571 00:49:44
LAN 100M/Full 2834 5499 0 621 263 00:50:02
Connection Speed 4768 kbps 448 kbps
Line Attenuation 37 db 8 db
Noise Margin 6 db 24 db
Now chaps, I don’t know how but I’ve managed to get the wires into the Sky adapter. Which I’m very pleased about, only problem is if I click
services on Sky it say phone not connected. But I’ve checked both ends of the sky cable, everything seems OK
Oh can I just say despite the better speed the web pages sometime are very slow to load.
Regards Wattsy
pierre_pierre
Re: Slow Speed
Hi Wattsy, if you didnt use a tool and it is IDC, it is difficult to make sure that the two blades of the terminal have cut through the insulation,, did you manage to find the section on the instructions I sent,  it has very good photo of the tool in use, about 3/4 down the page.  Most of it even my wife could understand, Lucky she doesnt read this forum Grin Grin
wattsy
Re: Slow Speed
  Hiya
Yes I did have a quick look but I'll have another look after I had my tea, what did you think of the last lot of results??????
    Regards Wattsy
Oldjim
Resting Legend
Fixes: 63
Re: Slow Speed
Last time I did it I borrowed my wife's tweezers to push the wire in  Embarrassed
pierre_pierre
Re: Slow Speed
sorry my dear, I am the hands on man, the other two are the number crunchers Roll_eyes
