Slow Speed
- Re: Slow Speed
Slow Speed
31-03-2014 5:50 PM
Hi all,
Having an intermittent problem with my DSL connection. Speed seems to have dropped and is now fluctuating from 3Mb to 0.1. (this is wired). Our normal speed is around 14Mb.
Line is normally super stable, nothing has changed our end.
Online Status
IP Address TX Packets RX Packets
192.168.2.1 665205 428622
ADSL Information ( ADSL Firmware Version: 332201_A)
ATM Statistics TX Cells RX Cells TX CRC errs RX CRC errs
559416 19952690 0 7
ADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
ADSL2+(G.992.5) SHOWTIME 1078000 17179678 2 32
Any help is much appreciated.
Regards,
Alan
Online Status
559416 19952690 0 7
Regards,
Alan
Message 1 of 4
(950 Views)
3 REPLIES 3
Re: Slow Speed
31-03-2014 6:22 PM
Are you able to try your router in the test socket, also with a new micro filter
Can we also see the speeds on: https://portal.plus.net/my.html?action=data_transfer_speed
Info for getting to the bt test socket: http://www.coolwebhome.co.uk/faceplate/
Might also be worth raising a fault at https://fault.plus.net but they will ask for the above to be done anyway during the fault checks
Message 2 of 4
(475 Views)
Re: Slow Speed
31-03-2014 6:28 PM
Speed has gone back to normal on its own. If it goes back down I shall try what you suggest. Is it possible to see a graph of connectivity?
Requested info:
Estimated line speed:
Current line speed:
15.1 Mb
jim:quote
Requested info:
Current line speed:
15.1 Mb
jim:quote
Message 3 of 4
(475 Views)
Re: Slow Speed
31-03-2014 6:32 PM
If it does go back down then I'd try the test socket, one of the PN team will be able to post your connection graph.
Message 4 of 4
(475 Views)
