Slow Speed started tonight.
- Slow Speed started tonight.
Re: Slow Speed started tonight.
09-04-2015 4:25 PM
10-04-2015 7:27 PM
10-04-2015 7:36 PM
10-04-2015 11:11 PM
11-04-2015 1:29 PM
If you fancy some detailed monitoring, please download RouterStats (full) using the link below and configure as per the other link, with the exception of making the maximum on the RX synch speed graph 24000kbps.
Then post the RX noise plot - then we will keep a watch on things.
12-04-2015 7:07 PM
12-04-2015 9:01 PM
13-04-2015 3:19 PM
14-04-2015 11:27 AM
Its a bit difficult to tell for sure. This is not configured as I recommended (see link below) as there is not enough granularity" (resolution) in the data sampling rate. To see clearly what is happening requires a 10 second sample rate.
Also it is useful to overlay the synch speed on the Rx noise plot.
What the plot appears to show is a rock solid 6dB SNRM - if the same is seen on a higher resolution plot, then all is fine there.
14-04-2015 1:12 PM
How do you overlay them? I have all the graphs but there currently seperate (on different tabs).
dick:quote
14-04-2015 1:24 PM
If you right click on the Rx noise graph you will see an option to overlay the sync speed.
14-04-2015 2:24 PM
dick:quote
14-04-2015 9:21 PM
15-04-2015 6:31 PM
Can you please change the Y axis maximum on the Rx synch plot to 24000 kbps.
Quote from: Townman ... configure as per the other link, with the exception of making the maximum on the RX synch speed graph 24000kbps.
15-04-2015 8:18 PM
