Slow Slow unable to use
Re: Slow Slow unable to use
What are the estimates for the line ?Huh
Fixes: 52
You can answer that question yourself, just put your phone number in the DSL Checker.
It will also show if there any other faster services available to you.
Does say up to 3.5 so is 2 too much to expect Though I dont fully understand  the chart I dont think you should all want to wash your hands of me  Easy get out for Plusnet !!
Response time (latency)      This is todays result with the Which speed tester The BT one does not complete
2394 ms
Download speed
0.6 Mbps
Upload speed
0.1 Mbps
Any sugestions
ts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 13949882 15426631 0 13691 6128 68:51:31
LAN1 Link down 3660021 3387010 0 7400 14003 68:53:41
LAN2 100M/Half
LAN3 1000M/Full
LAN4 Link down
WLAN b/g/n 145M 2308274 1772910 0 10254 1192 68:53:10
WLAN a/n 300M 73547 48369 0 379 19 68:53:04
ADSL Link Downstream Upstream
Link Rate 2019 Kbps 447 Kbps
Line Attenuation 68.5 dB 43.4 dB
Noise Margin 5.3 dB
All Star
Fixes: 15
If you post a screen image of the DSL Checker results (ensuring you remove your phone number) someone will explain the results.
System Up Time 88:34:30
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 2805235 2784968 0 121930 98564 08:09:25
LAN1 Link down 6417077 6326006 0 9085 8620 88:34:14
LAN2 100M/Half
LAN3 1000M/Full
LAN4 Link down
WLAN b/g/n 145M 2902668 2256758 0 9863 1146 88:33:43
WLAN a/n 300M 160137 48369 0 338 14 88:33:37
Noise Margin 6.1
1. Best Effort Test:
Download Speed : 5.34 Mbps
2. Upstream Test:
Upload Speed : 0.08 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
This is unusally high but the tester does not complete properly   Would be happy if this was right
The Which? tester is unadulterated rubbish. Use speedtest.net or thinkbroadband.com/speedtest.
The BTW tester gives me  false readings and wont complete and the OKLA one will not complete
Could we be looking at a browser or network-security-suite problem? Try disabling any 3rd-party AV/security tools and run the speed test in an "incognito" or "private browsing" window.
Some times this is 6 or 7 The Okla says 1. something  I do Know something is wrong but am unable to understand what
Download Speed : 3.81 Mbps
2. Upstream Test:
Upload Speed : 0.28 Mbps
Sorry I dont understand  but I do Know there is something wrong I should get a reasonable performance with this download  But the Okla thing says 1.2 to 1.4
Results Image not loaded
Download Speed : 5.69 Mbps
2. Upstream Test:
Upload Speed : 0.29 Mbps
Fixes: 57
Hi @stathe
I have just had another look into this for you.
Your router is syncing at just above 2Mbps - which sits well in your estimated speed range on DSL Checker.
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status:   NTE Power Status: PowerOn Bypass Status:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 43.4 68.5
SNR Margin: 16.3 5.4
Errored Seconds: 0 48
HEC Errors: 0
Cell Count: 0 0
Speed: 447 2019
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 1 -- 1 to 3.5 Available -- --
WBC ADSL 2+ Annex M Up to 1 Up to 0.5 1 to 3.5 Available -- --
ADSL Max Up to 1 -- 0.75 to 2.5 Available -- --
Fixed Rate 0.5 -- -- Available -- --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap U
VRI N
NTEFaceplate N
Last Test Date 19-03-2018
I also had a look at your connection to see if there were any dropouts which might be affecting your speed, however i can't see anything at all on this visual read out;
I'm afraid I must agree with my colleagues previously and state that the line is performing correctly and within estimates.
Whilst I have not provided much fresh information, I hope the visual stimulant in this message helps put things into perspective.
 MoR
