Slow Slow unable to use
stathe
My speed has become very very slow today despite my router speed being as usual very little will work problems doing this
84 REPLIES 84
stathe
Re: Slow Slow unable to use
This is still very slow and barely works despite plusnet doing things to it
stathe
The situation is still the same despite my contact by phone yesterday and the day before and doing  as instructed
Fixes: 1,600
Sorry to hear you're having speed issues.
Our tests are showing a very high amount of errored seconds on your connection.
Can you run through the steps here and then report a fault to us here?
stathe
Well I have done all that and it is still very slow
stathe
something wrong with my Plusnet I should be able to get 2 at least
LaurenB
Fixes: 131
Hi @stathe
Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection, completing the further diagnostics at the end? This will store the result on the supplier system and will help us if we report a fault to our suppliers.
Let us know how you get on.
 Lauren Barry
stathe
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 1.67 Mbps
2. Upstream Test:
Upload Speed : 0.15 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
stathe
This is how it is not always as good as the previous one and does not complete properly but
Download Speed : 1.11 Mbps
2. Upstream Test:
Upload Speed : 0.03 Mbps
stathe
I am unable to complete the test  as there is something wrong Thank you
Fixes: 1,600
Sometimes the test can fail like that. It's not indicative of a fault with your service.
It's just the wholesale test itself not working as it should be.
Testing your line now there aren't any errored seconds showing and your router is in sync at 1.9mbps which is within expectations of your line shown at www.dslchecker.bt.com
The result from the speedtest you've done is about right for the sync rate.
Your connection is also a lot more stable in recent days:
Did you plug your router into the test socket?
stathe
Unfortunately things are not getting any better the tests dont work and I get the impression that you think it may be my kit I think the bt test should work and the fault may be in the line  Yes I have used the test socket
Pkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 36682 32962 0 14241 18995 00:09:32
LAN1 Link down 33525 31683 0 25711 38091 00:11:42
LAN2 100M/Half
LAN3 1000M/Full
LAN4 Link down
WLAN b/g/n 145M 5151 5036 0 2977 1602 00:11:11
WLAN a/n 300M 0 0 0 0 0 00:11:05
ADSL Link Downstream Upstream
Link Rate 2019 Kbps 447 Kbps
Line Attenuation 68.5 dB 43.4 dB
Noise Margin 6.0 dB
stathe
Download Speed : 1.2 Mbps
2. Upstream Test:
Upload Speed : 0.11 Mbps
MatthewWheeler
Fixes: 479
As @Gandalf advised the speeds are within the estimates for the line and as such there isn't much further we can do.
 Matthew Wheeler
stathe
Well I dont  find that Helpful it is obvious to me that this is not working as it should I have previously had speeds approaching 2  fairly consistently and have not  been told "bad luck old chap " those are the rules I dont believe things have changed to down grade my connection The BT  tests dont even work properly
