Slow P2P Speeds
- Slow P2P Speeds
Slow P2P Speeds
24-05-2009 12:01 PM
I have been a Plusnet member for over 2 weeks now on the ultimate package and I am getting really slow P2P download speeds (not seen higher than 90kBps).
I came to Plusnet from S*y Broadband where i was hitting P2P download speeds of 1800kBps.
I am using a Belkin F5D8631-4 Modem Router (same one I was using with previous ISP and achieving 1800kBps).
I am just wondering if anyone can help me find a reason as to why my speeds are so poor.
Thank you for yor time.
Kyle =D
Re: Slow P2P Speeds
24-05-2009 12:38 PM
Re: Slow P2P Speeds
24-05-2009 12:55 PM
Re: Slow P2P Speeds
24-05-2009 1:37 PM
Also, I left my torrents running overnight last night and i checked my broadband usage via the Plusnet main site and it said i have used 0kb during off peak.
Thats very confusing lol.
Re: Slow P2P Speeds
24-05-2009 1:45 PM
Re: Slow P2P Speeds
24-05-2009 1:49 PM
Do you have any indication as to why I am not getting the speeds I should be?
Re: Slow P2P Speeds
24-05-2009 2:02 PM
but after midnight you should get the max speed that the p2p network your using can give.
max sure you upload is set to 80% of the maxium on your line ie (80% of the upload result on speed test) if your using torrent clients
Re: Slow P2P Speeds
24-05-2009 2:13 PM
My uploads are fine, like 80kBps - 120kBps, its just my downloads which are shocking.
Surely something must be wrong if I am not getting downloads higher than 90kBps after midnight?
Re: Slow P2P Speeds
24-05-2009 2:20 PM
if your not on the adsl2+ trial then i think when your downloading set it to 32kB/s when just seeding allow it full line speed on upload
i think the upload being maxed out and slowing downloads down is your problem as you moved from a llu provider to PN which on currently sold products have diffrent upstream sync's
Re: Slow P2P Speeds
24-05-2009 2:25 PM
Re: Slow P2P Speeds
24-05-2009 2:32 PM
5715kbps Download and 298kpbs Upload.
Why cant I get a fraction of these speeds on my P2P app?
Re: Slow P2P Speeds
24-05-2009 2:43 PM
the upload fig's ive seen qouted look a little low should be able to get 380kbps if your syncing at 448kbps
how to get sync rates from router
http://www.kitz.co.uk/adsl/frogstats.php
Re: Slow P2P Speeds
24-05-2009 3:03 PM
Downstream Upstream
Data Rate(Kbps) 8096 448
Re: Slow P2P Speeds
24-05-2009 3:26 PM
Re: Slow P2P Speeds
24-05-2009 3:43 PM
015********
Phone exchange:
KENDAL
Estimated line speed:
6 Mbps - Checked on 2009-04-30 12:42:27
Current line speed:
7150
