Slow FTTC
- Slow FTTC
Slow FTTC
31-12-2012 2:52 PM
This morning I had adsl2, 48.5 dB attenuation with a 4.8Mb/0.9 sync speed on the evil talktalk.
After install I now have 5Mb download, 0.5 upload. I could have gotten 5Mb on adsl if I rebooted during the day.
I know it's the training period, but the estimate was 10/1 and the line was pretty decent at adsl considering it's length. The cabinet is still around 1 mile away,
I guess my question is this: Is it going to get any better? Or do I just get to pay fttc prices for slightly worse than my old adsl connection?
Re: Slow FTTC
31-12-2012 2:58 PM
Post the result from the BT speedtest - diagnostic version and Current Line Speed from https://portal.plus.net/my.html?action=data_transfer_speed
Re: Slow FTTC
31-12-2012 3:03 PM
http://speedtest.btwholesale.com/
You will probably see the same poor speeds at this stage.
At the end of the test, click Further Diagnostics. After those tests run, you will be given a page which shows your IP profile. What is shown for that?
Edit: Somehow managed to double-post with OldJim in spite of the page timing out when posting.
Re: Slow FTTC
31-12-2012 3:06 PM
Re: Slow FTTC
31-12-2012 3:25 PM
Current line speed can't be accurate sadly, as it's still a good 1600m to the cabinet
Estimated line speed:
10Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-18 20:12:15
Current line speed:
37 Mb
speedtest:
Download: 5.32Mb
Upload: 0.58Mb
Further diagnostics:
Download speedachieved during the test was - 5.32 Mbps
For your connection, the acceptable range of speeds is 3.58 Mbps-0 Mbps.
IP Profile for your line is - 5.11 Mbps
Upload speed achieved during the test was - 0.58Mbps
Additional Information:
Upstream Rate IP profile on your line is - 2 Mbps
Re: Slow FTTC
31-12-2012 3:53 PM
http://www.thinkbroadband.com/news/4488-bt-reduce-minimum-fttc-speed-and-reveal-fttp-will-not-replac... Tells me that you have been provisioned on 40/2 because of the estimated speeds
Re: Slow FTTC
31-12-2012 4:04 PM
Quote from: Oldjim Oh [censored] unless something is badly adrift you shouldn't even be on Fibre although with that distance to the Cab I still wonder if there isn't a problem
I had hoped as the line was actually reasonable, 4Mb stable at 5.5km , that cutting the distance in half would get me something approaching previous generation broadband, 10Mb would still be 2.5 times faster!
Re: Slow FTTC
31-12-2012 4:09 PM
Re: Slow FTTC
31-12-2012 6:12 PM
4.5Mb down (exactly the same as adsl)
0.6Mb up (300k less).
Welcome to the future!
It sucks
Re: Slow FTTC
02-01-2013 2:55 PM
I can see you've raised a fault online, if this is still an issue please go back and complete the questions at http://faults.plus.net
Adam
Re: Slow FTTC
03-01-2013 11:44 AM
adie:quote
Re: Slow FTTC
03-01-2013 3:20 PM
Re: Slow FTTC
07-01-2013 8:55 PM
The bad news: Speed is appalling!
Good new: Graphs!
Does this mean anything to anyone? Sadly I'm only just getting started with vdsl.
stats attached
Re: Slow FTTC
07-01-2013 10:42 PM
Re: Slow FTTC
07-01-2013 10:51 PM
