Slow Download Speeds
JohnHolland
Hi there
I've just started having trouble with my download speeds today, which were fine last night. Just thought I'd ask to see if I could get any help.
I've attached my router stats, the results of a Connectivity check on my router and some speed test results using broadbandspeedchecker.co.uk as I couldn't get any other speed checker to work.
15 REPLIES 15
Fixes: 1,483
Re: Slow Download Speeds
can you post the results of this after going through further diagnostics speedtest http://speedtester.bt.com/
and also
what this says  https://portal.plus.net/my.html?action=data_transfer_speed for current line speed
JohnHolland
Hi
Sorry for the delay, I had to try several times for the BT test to work.
The results plus my line speed are attached.
JohnHolland
Apologies, I misread your post. I'm attempting to run the Further Diagnostics now.
JohnHolland
I keep receiving the error message below when I attempt to run Further Diagnostics, but I will keep attempting to retry whilst I wait for a response.
Also added the latest speedtest result just to show that the latency isn't an issue.
JohnHolland
Finally got it to work. Should I continue with the 3rd test or is this all the information you require?
Oldjim
Resting Legend
Fixes: 63
Given that it doesn't explain the problem - please do the next test
JohnHolland
I'm having trouble following the instructions on how to do the 3rd test.
I get the instructions shown in the attachment below, but when I follow these I do not get the option to change the name of the user. If I try to create a new user with the name speedtest@speedtest_domain I get an error message for using a name with the @ symbol in it.
Using the Windows 7 specific instructions (also shown below) I just reach a dead end where the thing the instructions is telling to do is not possible as the option to do so does not exist.
Any Advice?
Oldjim
Resting Legend
Fixes: 63
That is rather confusing
What you need to do is change the username etc. in the router
If the router demand a password just type in blank
The reference to Windows is if you have a usb modem
KaotiK
jsut come home to crap speeds myself, hopefully a temp issue.
JohnHolland
Quote from: Oldjim
If I try to change the username I just come up to the message shown in the attachment below and if I try to add a new user, as I said before, I just get an error message (also shown below).
Oldjim
Resting Legend
Fixes: 63
You have it wrong
You change your username or ASDL login setting in the router from  username@plusdsl.net to speedtest@speedtest_domain
i don't have that router so I can't be any more specific
JohnHolland
Well in that case I know what my current user is, but I have no idea where I need to go in my router options to make such a change.
I've been looking around the options for the past 10 minutes and I can't find anything that will allow me to do so.
I'm using a Thomson TG585v8 if you can give me any help.
JohnHolland
Still stuck in the same situation, would appreciate any help.
PeeGee
Sorry, don't know the v8, but for the v7 it is via:
Broadband connection
  Internet services
    view more
with luck, the v8 may be similar  Roll_eyes
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
