Slow Download Speed
- Slow Download Speed
Slow Download Speed
29-01-2010 4:40 PM
Hi, my IP profile is currently at 5000 Kbps. However my download speed is struggling to get above 3000Kbps. Has anyone any idea why this would be?
Download speedachieved during the test was - 3000 Kbps
Additional Information:
Your DSL Connection Rate :5920 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
Many Thanks
Many Thanks
Message 1 of 5
(1,110 Views)
4 REPLIES 4
Re: Slow Download Speed
29-01-2010 5:06 PM
The BT results are not correct for download speed - see this topic
Tony
Tony
Message 2 of 5
(479 Views)
30-01-2010 12:46 PM
Thanks Tony, I tested with my broadbandspeed as well and got the same results. It's risen slightly today but still not great.
Message 3 of 5
(479 Views)
30-01-2010 12:51 PM
Are you connected to the router wired or wireless?
Message 4 of 5
(479 Views)
30-01-2010 5:49 PM
Its plusnet - there are lots of us suffering the same fault, yet PN seem insistent on trying to point the finger anywhere but at their own network. Try a speed test at off peak times - bet you its better.
Of course it will then be BT's fault - even if your exchange is green. Theres not even the slightest possibility its PN's fault... never.
Message 5 of 5
(479 Views)
