Slow Connection For Charity on Business Line
- Slow Connection For Charity on Business Line
09-11-2010 1:36 PM
We are a charity that has been using plusnet for a number of years using a business line. Recently we have been making more use of internet but have noticed that speeds are slow. Our profile seems to be at 2000 but we are only about 1.8km form the exchange.
Should we be expecting more?
What steps do we need to take to see if we can get something better out of our connection.
Thanks, Mark
Re: Slow Connection For Charity on Business Line
09-11-2010 2:04 PM
This explains how to get them http://www.kitz.co.uk/adsl/frogstats.php
10-11-2010 8:43 AM
Down Up
Connection Speed 2656 kpbs 448 kpbs
Line Attenuation 40 db 22 db
Noise Margin 11 db 23 db
10-11-2010 8:53 AM
Are there multiple extensions on the phone line and if so is the router plugged in to the master or an extension?
Do you have an extension lead on the router to phone socket?
10-11-2010 9:15 AM
does you phone line go straight to the outside world, or does it go via the Hosrpital , I see your address is South Lodge, they seem to have been mucking around with NHS phones in Essex recently, i.e. how does the 800 patient line link in to yours?
10-11-2010 9:44 AM
The line is direct with BT organised by ourselves and nothing to do with any hospital or patientline infrastructure...
There is other equipment and phones connected to the line so I guess that is our next port-of-call.....
I will report back!
Thanks for all your help
10-11-2010 10:41 AM
If you are amongst the fortunate majority you will find one telephone socket with some sort of BT logo and the lower part of the faceplate attached with two screws. This is the BT Master Socket. You can remove the screws and pull out the faceplate. If your telephone extensions are correctly wired this should cut-off all the extensions as these should be wired in to this faceplate. You need to check this and, obviously, you need to do this at a time when you are not expecting any important phone calls! Then plug the router into the test socket that was behind the faceplate and see if the router stats have changed.
10-11-2010 11:18 AM
I think the last diagram on that page is going to be most relevant to you.
10-11-2010 11:49 AM
Quote from: jelv Have a read of http://www.plus.net/support/broadband/help_and_setup/microfilters.shtml
Actually this isn't very good as the picture captioned "Telephone Master Socket" doesn't look at all like a typical telephone master socket, it looks like a typical telephone extension socket!
10-11-2010 1:36 PM
10-11-2010 1:39 PM
15-11-2010 5:21 PM
15-11-2010 6:59 PM
