Slow Broadband
- Re: Slow Broadband
Slow Broadband
22-01-2014 4:02 PM
Last week I returned from a 5 week period away. During that period I had my router switched off. When I switched it back on I had frequent disconnections, when it finally settled I was only getting 283kb/s downstream and 444 kb/s upstream. Before going away I was getting 6-7mb/s downstream.
I have tried 2 routers, and am currently using my Billion 7800N cabled.
I raised a question (#80114799) on Monday morning, and have had no communication back. Could someone please look in to this, as a connection at the above speeds is useless!
BT Test Results
1. Best Effort Test: -provides background information.
Download Speed
0.18 Mbps
0 Mbps 0.25 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.18 Mbps
For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
IP Profile for your line is - 0.25 Mbps
Upload Speed
0.36 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.36Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Billion 7800 Stats
ADSL Status
Parameters
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operational Mode ADSL2+
Upstream 444
Downstream 283
SNR Margin(Upstream) 31.9
SNR Margin(Downstream) 13.9
Line Attenuation(Upstream) 20.3
Line Attenuation(Downstream) 38.0
BT Test Results
Download Speed
0.18 Mbps
0 Mbps 0.25 Mbps
Upload Speed
0.36 Mbps
0 Mbps 0.83 Mbps
Billion 7800 Stats
ADSL Status
Parameters
Upstream 444
Downstream 283
Message 1 of 8
(1,149 Views)
7 REPLIES 7
Re: Slow Broadband
22-01-2014 4:57 PM
Hi Nigel60,
Sorry you've not heard anything back on your ticket about this yet. I can see that the connection has been much more stable over the last 22+hours so I've submitted an SNR reset for you.
You should start to see some improvement within the next few hours.
Adam
Adam
Message 2 of 8
(626 Views)
Re: Slow Broadband
22-01-2014 5:16 PM
Thank you for that, the downstream has already gone up to 9431kb/s. However the uploadspeed would appear to have been capped again (443 kp/s), could you please arrange for it to be uncapped again, as it was before I went away.
Thanks in advance
Thanks in advance
Message 3 of 8
(626 Views)
Re: Slow Broadband
23-01-2014 3:10 PM
Hi there, it's still uncapped, not sure what's happening to keep it at 448k at the moment - if it's not improved when the SNR reset has finished going through we could always try a second one, just in case that side of things didn't take. Should be able to do that after the weekend if it's not improved.
Message 4 of 8
(626 Views)
Re: Slow Broadband
27-01-2014 7:53 AM
hi
had a relatively stable weekend, just a couple of drops, one on Saturday during a thunderstorm. Each reset the upload speed has come back at 443 KB/s, could you please try and do the reset from your end again.
Message 5 of 8
(626 Views)
Re: Slow Broadband
27-01-2014 3:28 PM
That's been requested for you, hope it improves things - should take effect within 4 hours or so, please let us know.
Message 6 of 8
(626 Views)
Re: Slow Broadband
31-01-2014 9:54 AM
Just a quick update, my download speed is now good, and stable, but upload is still stuck at 443Kb/s. Could you have another look at the upload speed from your end?
Regards
Nigel
BT Test Results
Download Speed
7.26 Mbps
0 Mbps 21 Mbps
Download speedachieved during the test was - 7.26 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.53 Mbps
Upload Speed
0.38 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.38Mbps
Billion 7800n router stats
ADSL Status
Parameters
Upstream 443
Downstream 9675
SNR Margin(Upstream) 28.5
SNR Margin(Downstream) 5.3
Line Attenuation(Upstream) 20.4
Line Attenuation(Downstream) 38.5
Regards
Nigel
BT Test Results
Download Speed
7.26 Mbps
0 Mbps 21 Mbps
Upload Speed
0.38 Mbps
0 Mbps 0.83 Mbps
ADSL Status
Parameters
Upstream 443
Downstream 9675
Message 7 of 8
(626 Views)
Re: Slow Broadband
31-01-2014 12:28 PM
Good news, upload speed has gone up, thanks if Plusnet helped if not thanks for your help in general.
ADSL Status
Parameters
Upstream 1192
Downstream 9751
SNR Margin(Upstream) 5.9
SNR Margin(Downstream) 6.7
ADSL Status
Parameters
Upstream 1192
Downstream 9751
Message 8 of 8
(626 Views)
