Slow Broadband Speeds
Beermonsta
Morning!
I have just noticed a sharp drop in speeds again from my normal top rate of 812kb/s right down to 102kb/s this morning, could you reset the line or something before I have to ring OR once again please?
Thanks In Advance
Glenn Smiley
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: Slow Broadband Speeds
Resetting the line is useful if the SNR has increased or similar, however your line is still connected at a good rate:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 18.1 33.5
SNR Margin: 6.5 5.8
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 11058874 45250870
Speed: 1183 9463
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
Beermonsta
Thanks Chris,
My line has returned to its previous speeds, I rebooted my router  (just in-case!), ive also just completed the BTWholesale speed test aswell for the suppliers records.
Thanks again
Glenn Smiley
Chris
Legend
Fixes: 169
Good to hear, thanks for letting us know. However I didn't reset the line Wink
