Sloooooooow FTP uploads.... Why am I being throttled??
- Re: Sloooooooow FTP uploads.... Why am I being thr...
21-04-2014 8:10 PM
I thought PlusNet didn't throttle, just prioritised?
Please help.
(The FTP server is on a Dell server with 2 x quad-core CPUs and 24GB of ram so the hardware definitely isn't the issue here)
Re: Sloooooooow FTP uploads.... Why am I being throttled??
21-04-2014 8:17 PM
Are you sure you have your units (bits (b) and bytes (B)) correct? Connection speeds are always in bits and software tends to report speeds in bytes. 600KBps = 4800Kbps which wouldn't be far off if the remote user is on an 8Mbps connection.
21-04-2014 8:17 PM
What ftp client are you using and is your anti virus live scanning the upload
21-04-2014 8:25 PM
21-04-2014 8:27 PM
Another thing you could try - disable the firewall in the router
21-04-2014 8:28 PM
21-04-2014 9:32 PM
21-04-2014 10:12 PM
21-04-2014 10:15 PM
21-04-2014 11:24 PM
Quote from: tension83 600KBps
If you are expecting a lot faster than 4800Kbps upload (which is what you are getting) I'm assuming that you must be on fibre - is that correct? Also if the remote end is on only 8Mbps (I assume that is sync speed) there is very, very little scope for faster speed even if you are on fibre.
