Sinking profile/ speed
- Sinking profile/ speed
Re: Sinking profile/ speed
18-09-2007 10:44 AM
Whilst I do agree with your suggestion, I would also suggest that the noise margin is fluctuating for a reason and using the DLM tool would potentially cause intermittency if you were to be forcing down to noise margin.
18-09-2007 10:58 AM
I'm lost!!!! Back to my earlier post: worth a spin to ask for a SNR reduction, or not? Were you intending to attach the averages?
Quote from: James Hi Jim,
18-09-2007 11:03 AM
It's not really worth it because your SNR seems to be fluctuating. But this could be caused by your modem, in which case going for the router that Jim has suggested could be a good idea.
18-09-2007 11:12 AM
That is why I used to force my default margin down if I needed to resynch at those times. I very quickly found the sweet spot (in my case a synch speed of about 3,500kbps) where the line held up for long periods.
The point about altering the noise margin is not to force the speed up to its maximum but to use it to achieve a stable speed.
If changing to a router reduced the fluctuation then you can push the speed higher.
One of the things a good router does is effective bit swapping so that the tones where there is most noise are dropped. This in itself reduces the variation in reported noise margin.
20-09-2007 7:23 AM
At this rate I'll need a deep sea diving bell to be on line. When I went on yesterday morning things had improved, vut haf to be out ay hospital sp tuend off computer then it happened , the lowest figs ever, and still the same this morning.
IP profile for your line is - 350 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4000 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 318 kbps
20-09-2007 9:00 AM
I had a similar problem. I brougt a new modem, but no real improvement.
My ADSL router is about 60 feet from Master socket.
I disconnected the bell wire at the master socket, and extend only the bluewhite / whiteblue wires to the extensions.
I use Solwise micro filters purchased back in 2003 in front of every phone.
A filter I brought from a local hardware store was dreadful.
Results were dramatic.
Have a look at:
http://www.dougrice.plus.com/Erlangs/adsl.htm
My ADSL have been very good for the last week.
I now use an eTEC modem which does not list ADSL SHOW CHANNEL figures.
20-09-2007 9:06 AM
20-09-2007 2:22 PM
OT, but I have big problesmw with comp today, so am posting from elsewhare. James there is a rssponse to the question you raised from support.
Quote from: Jameseh I think this really highlights the need to be plugged directly into your master socket via a filter. When extensions and lengthy copper or aluminium wiring are brought into play, especially on max, the possibility of resynchronisation events at a lower speed is far more likely than if the optimal setup were to be used.
20-09-2007 2:24 PM
Hope you manage to sort things out soon.
20-09-2007 2:29 PM
As it happns the previous owner had that done aleady.
20-09-2007 4:51 PM
Remember that if you are some distance from the master socket you may be better off keeping the router plugged into the master socket using a short length of decent cable and linking your PC to the router using wireless or Homeplug-type links. What matters to the exchange is how the local-loop link to your router behaves, not what is behind it.
20-09-2007 6:03 PM
Certainly my experience where I removed the ring wire with an immediate improvement before fitting their filtered faceplate and then put it back after fitting it showed no reduction in speed or stability.
20-09-2007 6:36 PM
My ADSL is about 60 feet from master socket, and my three phones are via 2003 vintage Solwire Micro filters on the original extension wiring.
Only the A & B wires are extended to the slave sockets, and all is working very well now.
Their faceplate uses the six wires,
The unfiltered ADSL is extended on the spare wires 1&6
The filtered A&B wires and filtered BELL on the standard wires.
www.bt.com do not seem to sell a solution other than a wireless solution!
20-09-2007 11:11 PM
21-09-2007 9:41 AM
Quote from: Jameseh Hi Lucerne,
Sorry - I didn't copy and paste the averages!
It is possible that you may just have to deal with the fluctuations that you are seeing, although it is possibly down to your modem. I'd always recommend an upgrade to a router, because then you're less likely to have software problems and they're generally a lot more stable that a USB Modem, especially as you don't have to reconnect every time that you start up your computer.
Hilited part.... When my S-i-L got me out of my computer disaster yesterday, he too mentioned routers, and said he had an old Netgear that he would lend or give me to see if it would help my problems. Also opined that he thought a wireless connection to the router at master socket might be 'flakey' because of the wall and floor between master and computer. In his house operating his lap top in the romm immediately beihind the hall, that has the BT socket is out but in the kitchen and dining room at rear of house it works.
BTW this morning at 6.30ish I synched at 4352, downstream actual was 410.
If I am being obtuse, so be it, but I sincerely doubt that contention can be a major problem at 6.30 am and anyway isn't IP profile based on synch rate.
