Significant packet loss: 12:30-15:30 26th; 10:00-present 27th
FIXEDTopic Options
- Significant packet loss: 12:30-15:30 26th; 10:00-p...
- « Previous
- 1
- 2
- Next »
30-03-2019 9:18 AM
I’m glad to see there’s no packet loss now. It’s difficult to advise definitively why the minimum latency has gone up, but it looks like something happened at 4am that day. It could be that your router re-synced then and the gateway from there has a higher baseline latency. I’d say as long as it remains low, steady and with no packet loss things should be good.
Re: Significant packet loss: 12:30-15:30 26th; 10:00-present 27th
30-03-2019 9:23 AM - edited 30-03-2019 9:23 AM
Thanks fo getting back to me. Just wondered if it was anything that might have occurred when you switched the IP assignments back and forth. I'll be keeping an eye, but I've marked as solved.
Thanks again.
30-03-2019 9:36 AM
No problem. Yeah it’s an odd one, it looks like at that time you still had the static IP and doesn’t look to be related to the immediate change between dynamic > static as that happened the previous evening.
There however does seem to be something not quite right with the initial dynamic IP you had, so I’m going to flag that to our networks team next week for further investigation internally.
Let us know how things go.
Message 18 of 18
(587 Views)
- « Previous
- 1
- 2
- Next »
