Signature Limits
- Signature Limits
Signature Limits
18-02-2009 10:58 AM
Quote Signatures should use no more space than 4 lines of standard sized text would, this includes any blank lines and images you choose to use.
I've already seen many instances of signatures that contain LARGE text which is already wrapping on my screen, and certainly taking up more landscape than 4 lines of normal text would. I have also seen quotations in sigs that exceed this limitation.
I will take the liberty of removing signatures that do not conform, within reason, to the forum rules
Please can you look at your signature and make any amendments that you think necessary.
B.
Re: Signature Limits
18-02-2009 11:07 AM
That better?
18-02-2009 11:11 AM
B.
18-02-2009 11:18 AM
18-02-2009 11:29 AM
B.
18-02-2009 11:49 AM
Don't you have a HUGE monitor Baz?
Will sort it out...
18-02-2009 11:51 AM
18-02-2009 11:52 AM
18-02-2009 12:06 PM
It's all about me, remember
B.
p.s. - there are no minimum Sig size limits
18-02-2009 12:08 PM
18-02-2009 12:29 PM
Quote from: Barry I have a dinky little 1280x800 EeePC, upon which some signatures are just using too much vertical landscape.
B.
I was using my 32" widescreen telly as a monitor when I did my sig. And didn't see much wrong with my sig except I didn't like the blue colour round the quote.
Oh and there is a minimum Sig size limit. Zero. You can't get a smaller sig than nothing.
18-02-2009 1:38 PM
18-02-2009 1:53 PM
[me=James_G]directs BZ to his profile, where he can select the option to not display any signatures in the forum, thus removing the issue entirely for him, and freeing up space on his pretend machine.[/me]
[me=James_G]also concedes that an EEE is better than an iPhone, since BZ doesn't appear to have locked any threads accidentally...[/me]
18-02-2009 2:27 PM
B.
If it's about vertical landscape, why have you left trailing blank lines on the end of your post?
See http://community.plus.net/forum/index.php/topic,72527.0.html
19-02-2009 4:18 PM
