Shpould I upgrade to FTTC
- Re: Shpould I upgrade to FTTC
27-08-2014 9:06 AM
Help....
I check last week and I can now get FTTC. The BIG problem is that it is saying I can expect speeds of 5.2 - 15mb on this service, currently with broadband I am getting a connection speed of 6 - 7MB. If I upgrade do you think I will end up with slower speed that I already have on broadband ?
When I check on several site sits listing my line length as 2.2KM.
Thanks for your help
Neil
Neil
Message 1 of 9
(2,185 Views)
8 REPLIES 8
27-08-2014 9:11 AM
Try doing a physical check of the distance to the cab from your property - you can then make an estimate yourself http://www.thinkbroadband.com/guide/fibre-broadband.html
if you are indeed 2.2km from the cab then your fibre speeds will be dire
Message 2 of 9
(1,605 Views)
27-08-2014 9:56 AM
The distance of 2.2 is fairly accurate have checked on Google maps and it's fairly accurate...
Message 3 of 9
(1,605 Views)
27-08-2014 3:04 PM
Oh no.
I'm 2.8km from my cabinet and expecting an FTTC install next week.
Message 4 of 9
(1,605 Views)
27-08-2014 3:38 PM
This chart was accurate for my installation.
http://www.increasebroadbandspeed.co.uk/2013/chart-bt-fttc-vdsl2-speed-against-distance
Message 5 of 9
(1,605 Views)
27-08-2014 7:34 PM
Quote from: mcclim Help....
Neil
which sites were these ? as far as i'm aware the sites list length to the exchange not your Fibre cab, With fibre it's the distance to the fibre cab not the exchange that matters.
Message 6 of 9
(1,605 Views)
28-08-2014 7:48 PM
The cabinet Igood point soy line length would reduce by approx. 0.75km if I upgrade to fibre
Message 7 of 9
(1,605 Views)
28-08-2014 8:40 PM
I'm on an 850m line from my cab on FTTC, my advice for anything over this length would be to order 40/20
See my speed test.
Edit: By the looks of that chart you have to ask yourself if anything over 1.5k is worth the bother!
See my speed test.
Message 8 of 9
(1,605 Views)
28-08-2014 10:39 PM
Are you in Eire ?
If so vectoring is working very well apparently.
Vertoring speeds...
Vertoring speeds...
Message 9 of 9
(1,605 Views)
