Should the phone affect my SNR this much?
- Re: Should the phone affect my SNR this much?
- « Previous
- 1
- 2
- Next »
20-10-2011 7:56 AM
Hi Sam,
If you can try the test socket with a normal filter then I can check out your line for you and see how it's performing.
Jojo
Jojo
Message 16 of 20
(408 Views)
24-10-2011 7:05 AM
Hi Jo,
I've had the phone in the test socket since Friday evening. I've got a slightly higher synch speed and things were stable (5440 from 5312). I disconnected this morning though as I read that the synch rate was not adaptive, so need to disconnect to see changes in synch rate if I change the setup (I could of sworn I used to see changes immediately :-[). Anyway, if I disconnect the phone completely and restart, the synch improves to 6112 (from 5440), so the phone is obviously causing some not insignificant issues. I'll buy a different cable for the phone when I can to see if that's the problem. Anyway, I'm pasting my stats from just before I disconnected (phone plugged in) and also my current stats (no phone). However, I'll have to plug the phone back in as we do use it.
JUST BEFORE RECONNECT, PHONE PLUGGED IN
Link Information -
Uptime: 2 days, 11:38:31
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,440
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 23.0 / 38.0
SN Margin (Up/Down) [dB]: 23.0 / 6.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 25 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 11 / 0
FEC Errors (Up/Down): 0 / 60,108,836
CRC Errors (Up/Down): 0 / 771
HEC Errors (Up/Down): 0 / 448
CURRENT STATS, NO PHONE AFTER RECONNECT
Uptime: 0 days, 0:23:34
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,112
SN Margin (Up/Down) [dB]: 23.0 / 7.0
FEC Errors (Up/Down): 0 / 420
CRC Errors (Up/Down): 0 / 3
HEC Errors (Up/Down): 0 / 2
Link Information -
Message 17 of 20
(408 Views)
24-10-2011 4:09 PM
If it's a DECT phone I've seen a few people recommend double filtering. Maybe that would help.
Message 18 of 20
(408 Views)
24-10-2011 4:45 PM
Why would a DECT phone interfere with a broadband router ?
I can understand the old analogue non-DECT wireless telephones being an issue, for example the old AM sets used 1.7Mhz which might knock out ADSL2.
A DECT phone uses frequencies 1880 to 1930MHz - similar to GSM mobile phones
21CN ADSL2+ uses frequencies 25KHz to 2.2MHz
Therefore they are magnitudes apart and should not be interfering, unless the phone is faulty or has a very noisy power supply adaptor.
Similarly because of the frequencies, DECT should not interfere with the router's WiFi either as that would be either 2.4GHz or 5GHz.
Message 19 of 20
(408 Views)
25-10-2011 9:35 AM
Message 20 of 20
(408 Views)
- « Previous
- 1
- 2
- Next »
