Short term speed problem (I hope)
- Re: Short term speed problem (I hope)
09-04-2014 12:35 PM
Over the weekend the broadband speed dropped. This appeared to coincide with the phone audio being noisy when making calls. I am currently checking this out with my phone provider but the problem appears to have cleared.
How long will it take the system to speed up my broadband?
I used to get about 7 Mbps download and the current BTW speed test has me at 0.48 Mbps.
For the record:
I'm running a BiPAC 7800N
ADSL
Mode ADSL2+
Dnl: 7,059 Kbps
Upl: 952 Kbps
SNR up: 6.8 dB
SNR dn: 12.1 dB
Line atten. up: 23.0 dB
Line atten. dn: 41.0 dB
For the record:
ADSL
Mode ADSL2+
Dnl: 7,059 Kbps
Upl: 952 Kbps
SNR up: 6.8 dB
SNR dn: 12.1 dB
Message 1 of 5
(676 Views)
4 REPLIES 4
09-04-2014 12:42 PM
Message 2 of 5
(441 Views)
09-04-2014 12:54 PM
Thanks for the quick reply. However the BTW test gives:
Download: 0.47 Mbps
Upload: 0.79 Mbps
Ping: 43.38 ms
: P
Download: 0.47 Mbps
Upload: 0.79 Mbps
Ping: 43.38 ms
: P
Message 3 of 5
(441 Views)
09-04-2014 2:19 PM
Hi strider,
Has this improved for you in the last hour and a half?
Message 4 of 5
(441 Views)
10-04-2014 5:23 PM
I checked it again to day and things are a lot better.
It is a bit slower than it is normally so I am keeping my fingers crossed that it will improve over time.
BTW results are:
Dnl: 5.72 Mbps
Upl: 0.91 Mbps
Latency: 26.63 ms
Thanks for the help : )
BTW results are:
Dnl: 5.72 Mbps
Upl: 0.91 Mbps
Latency: 26.63 ms
Message 5 of 5
(441 Views)
