Setting up an internal static IP address
- Re: Setting up an internal static IP address
10-12-2012 10:19 AM
I have trawled through the router interface but cannot find anywhere to change the internal network from DHCP to Static. Can anyone help?
regards,
10-12-2012 10:22 AM
You need to disable the router's DHCP server and manually assign IPs to the various devices on your network.
10-12-2012 10:26 AM
10-12-2012 10:59 AM
The router is a Technicolor TG582n. What am I missing?
regards,
10-12-2012 11:26 AM
10-12-2012 11:39 AM
10-12-2012 11:46 AM
Quote from: knowdice The other option is to set the printer to a fixed address outside of the normal DHCP range.
I'm sure that is a much simpler and straightforward option.
10-12-2012 11:49 AM
10-12-2012 12:14 PM
Thank you for that. Exactly what I wanted.
regards,
10-12-2012 12:16 PM
Quote from: johndeakin The router is a Technicolor TG582n. What am I missing?
As David's pointed out, you need to click 'Configure' towards the top-right. Not the most intuitive of interfaces I'll admit!
Edit: looks like you've sorted it
