Set A Broadband Price Limit
- Re: Set A Broadband Price Limit
10-02-2008 1:50 PM
In the Member Centre Set A Broadband Price Limit it says "Enter the maximum amount you want to spend on extra usage and click 'Change' ".
If you enter 1, for example, the message "Please enter an amount that is greater than your minimum limit." appears. So it is actually asking you to enter the maximum that you want to spend each month in total.
The wording should be "Enter the maximum amount you want to spend and click 'Change'" or perhaps "Enter the maximum amount you want to spend including extra usage and click 'Change'". The present wording is incorrect.
Message 1 of 5
(1,314 Views)
4 REPLIES 4
11-02-2008 11:16 AM
Do you think that changing it to:
"Enter the maximum amount you want to spend." would be appropriate?
Message 2 of 5
(511 Views)
11-02-2008 12:05 PM
Yes. That's why it was one of my two suggestions.
Quote from: alanf The wording should be "Enter the maximum amount you want to spend and click 'Change'...
Message 3 of 5
(511 Views)
11-02-2008 12:40 PM
Sorry, it's a Monday
I'll get a problem raised to content.
Message 4 of 5
(511 Views)
11-02-2008 4:26 PM
Thanks Jameseh.
Message 5 of 5
(511 Views)
