Service ID
- Service ID
Service ID
20-01-2010 11:30 AM
For some reason the BT tester will not run until I insert the Service ID, whereas it always used to run with the Plusnet domain name.
How can I find out my Service ID.
thanks
thanks
Message 1 of 4
(1,560 Views)
3 REPLIES 3
Re: Service ID
20-01-2010 11:33 AM
You need to check the box and then enter your phone number, that should be good enough.
Message 2 of 4
(789 Views)
Re: Service ID
20-01-2010 1:19 PM
Thanks for that, after a couple of failures it worked.
Good to see my profile has jumped from 2500 to 4000. I've been waiting for days to see if this was going to happen.
I see the gateway changed overnight, probably caused this..
Message 3 of 4
(789 Views)
Re: Service ID
20-01-2010 1:31 PM
Now keep an eye on this https://portal.plus.net/my.html?action=data_transfer_speed
Message 4 of 4
(789 Views)
