Sending email outside of plusnet account line
- Sending email outside of plusnet account line
13-06-2008 5:46 PM
As title really.
Is there a way of sending email from my plusnet account with the client on my computer (thunderbird) outside of my plusnet account line at home.
At present I can collect email at work, but not send any.
Cheers
Andy
Cheers
Andy
Message 1 of 5
(1,136 Views)
4 REPLIES 4
Re: Sending email outside of plusnet account line
13-06-2008 6:09 PM
Yes, you can set up authentication on your outgoing SMTP server and use your portal login/pass as the authentication details.
Message 2 of 5
(479 Views)
15-06-2008 1:58 AM
That simple
Will have to try that monday.
Cheers
Cheers
Message 3 of 5
(479 Views)
15-06-2008 7:11 AM
I would set it up while you are connected to your PlusNet line and make sure that it works from there before you try it from elsewhere, unless you are talking about using a desktop somewhere else.
Message 4 of 5
(479 Views)
15-06-2008 2:22 PM
Or you can use webmail, of course. Works from anywhere.
Message 5 of 5
(479 Views)
