Security - Thomson 4 port wireless router
- Security - Thomson 4 port wireless router
30-11-2008 7:58 AM
On the 2nd day of using Plusnet, I noticed an excessive usage. This has been identified as an unaccounted 149MB between 9-10am. I was web browsing at that time, and no automatic updates are enabled. My normal web browsing would not account for 149MB in an hour.
I have an ethernet cable connection, but at the time wireless was enabled. I did not realise that wireless was enabled by default. I have now disabled wireless.
What I want to find out is whether someone was using my wireless connection whilst I was connected via ethernet cable. I was running Windows XP at the time with Zonealarm firewall and AVG antivirus. Spybot revealed no issues.
Is there a problem with the intrusion via the router or with Windows XP?
Re: Security - Thomson 4 port wireless router
30-11-2008 10:03 AM
When you say you now have wireless disabled - in the Router I hope - it is apparently an option on the Thompson router, I havnt as I have two laptops one ethernet one wireless
30-11-2008 12:19 PM
30-11-2008 12:59 PM
30-11-2008 1:11 PM
30-11-2008 1:41 PM
I have a wired ethernet connection, but wireless was enabled by default. I do not have a wireless adaptor on my computer, so I cannot use wireless.
I did a hardware reset of the router when I discovered the unaccountable excessive usage and reset username and password.
What I am wondering is whether someone can use the wireless facility even though WPA is enabled.
NB. I'm using dial at present, although I managed to connect earlier this morning. Cannot connect to the Thomson gateway using the router. Just another problem with Plusnet?
30-11-2008 1:55 PM
30-11-2008 2:17 PM
Quote from: ogawd NB. I'm using dial at present, although I managed to connect earlier this morning. Cannot connect to the Thomson gateway using the router. Just another problem with Plusnet?
Failure to connect should not be "Just another problem with Plusnet" and the thought would horrify them. I suggest you give the Customer Service Centre a ring (0114 296 5198), there isn't a queue of calls waiting at present. Select the options that deal with a fault and take you through to speaking to an agent.
30-11-2008 2:24 PM
Planned Network Maintenance - Sunday 30th November 10:30am-11:00am
Internet Connectivity
Posted on: Sunday 30 November 2008, 03:40
When's this work happening?
Later on this morning.
What does it affect?
Routing between two of our London data centres.
How long will it take?
About 30 minutes.
What does the work involve?
Networking equipment will be reloaded at Telecity data centre where one of our data suites is located.
Is it likely to cause problems?
No.
Is there anything else I need to know?
No.
Kind Regards,
Customer Support
30-11-2008 2:46 PM
when i was on option 1 i used net limiter 2.
30-11-2008 3:49 PM
Quote from: spraxyt
Thanks. I spoke to CSC and it appears the problem getting a connection is not Plusnet's fault. I was using Ubuntu at the time - it was a Ubuntu problem.
I'm still unsure about this wireless issue.
30-11-2008 4:32 PM
30-11-2008 6:27 PM
Other speedtouch model 's have a ssid key and password on the bottom. Setup the router to allow access by registration for new devices, you use this so anybody who tries to access your wireless network have to enter ssid code and password (note this is not your connection to plusnet) and set wpa or wpa2
you only need to do this once when setting up your network
puddy
30-11-2008 6:38 PM
30-11-2008 8:22 PM
Quote from: alanf Please tell us the Ubuntu problem. I use Ubuntu and would like to know of any issue like this.
The Ubuntu problem was nothing to do with a wireless security issue.
I was having a problem connecting to the Thomson Gateway. If I plug in the router before booting up Ubuntu I can connect to the Gateway. But when I booted up Ubuntu and then pluged in the router I couldn't connect to the Gateway. I think that was the problem, but I'm not absolutely certain as yet. I am new to Ubuntu.
The wireless security issue came about when I was running Windows XP. If there is no possibility of a security issue with the Thomson router, then the problem I had with unexplained usage may be an XP problem. I haven't ruled that out.
