Security: TG582n transmits occasionally the serial number unprotected over wifi
- Security: TG582n transmits occasionally the serial...
Re: Security: TG582n broadcasts serial number unprotected over wifi
03-07-2013 12:52 PM
03-07-2013 12:57 PM
03-07-2013 1:16 PM
03-07-2013 2:14 PM
03-07-2013 2:20 PM
03-07-2013 4:44 PM
03-07-2013 5:38 PM
03-07-2013 8:01 PM
http://community.plus.net/forum/index.php/topic,116274.0.html
as this PN client found to his/her cost.
03-07-2013 8:23 PM
You have just created a loop, your link goes to the first post of this thread
Dan
03-07-2013 8:36 PM
http://community.plus.net/forum/index.php/topic,116018.0.html
Sorry guys.
It's reply #11 in that thread that I found memorable.
Re: Security: TG582n transmits occasionally the serial number unprotected over wifi
03-07-2013 9:09 PM
04-07-2013 10:47 AM
04-07-2013 11:05 AM
As far as transmitting the serial number of the 582n goes, I don't think that's very clever and I suspect that most people will think that the (Modem/)Router default login (admin) is fairly secure because the password (not a dictionary word and a mixture of alpha-numerics) is unique to each unit., that's until you transmit it to the local area of course!
04-07-2013 3:49 PM
Quote from: frank39 It's reply #11 in that thread that I found memorable.
Hi Frank,
The poster in the other thread is not using one of our routers.
Matt (other) is correct that the TG582n has a method to lock out WPS after many failed attempts. A link to the US-Cert description verifying this is here: http://www.kb.cert.org/vuls/id/JALR-8PKL26
The latest firmware updates (10.2.0.8 onwards) disable WPS upon the 10th failed attempt. The router will need to be rebooted to turn WPS back on.
Thanks,
Matt
04-07-2013 4:41 PM
My TG582n is running firmware 10.2.1.8, supplied by you (PN) and WPS seems to be permanently disabled, that is, there is no option to switch it on. I'm not complaining about that as I have always disabled it when the router has the option.
Frank
PS It doesn't say much for Netgear security if the dude in the bandana can hack the WPS while he's visiting his girlfriend!
