Security: TG582n transmits occasionally the serial number unprotected over wifi
- Security: TG582n transmits occasionally the serial...
02-07-2013 7:10 PM
# iw dev wlan0 scan passive
[tt]BSS a4:b1:e9:XX:XX:XX(on wlan0) -- associated
TSF: 0 usec (0d, 00:00:00)
freq: 2437
beacon interval: 100 TUs
capability: ESS Privacy ShortSlotTime (0x0411)
signal: -47.00 dBm
last seen: 193 ms ago
Information elements from Probe Response frame:
SSID: PlusnetWirelessD1745D
Supported rates: 1.0* 2.0* 5.5* 11.0* 18.0 24.0 36.0 54.0
DS Parameter set: channel 6
ERP: <no flags>
ERP D4.0: <no flags>
RSN: * Version: 1
* Group cipher: TKIP
* Pairwise ciphers: CCMP
* Authentication suites: PSK
* Capabilities: 16-PTKSA-RC (0x000c)
Extended supported rates: 6.0 9.0 12.0 48.0
HT capabilities:
Capabilities: 0x181c
HT20
SM Power Save disabled
RX Greenfield
No RX STBC
Max AMSDU length: 7935 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 8 usec (0x06)
HT RX MCS rate indexes supported: 0-15
HT TX MCS rate indexes are undefined
HT operation:
* primary channel: 6
* secondary channel offset: no secondary
* STA channel width: 20 MHz
* RIFS: 1
* HT protection: nonmember
* non-GF present: 1
* OBSS non-GF present: 1
* dual beacon: 0
* dual CTS protection: 0
* STBC beacon: 0
* L-SIG TXOP Prot: 0
* PCO active: 0
* PCO phase: 0
WPS: * Version: 1.0
* Wi-Fi Protected Setup State: 2 (Configured)
* Selected Registrar: 0x0
* Response Type: 3 (AP)
* UUID: 00f0dbd4-2ad1-53ba-9937-9f01182eaee4
* Manufacturer: Technicolor
* Model: Technicolor TG
* Model Number: 582n
* Serial Number: (THE SERIAL NUMBER WITHOUT THE CP)
* Primary Device Type: 6-0050f204-1
* Device name: Technicolor TG582n
* Config methods: Label, PBC
* RF Bands: 0x1
WPA: * Version: 1
* Pairwise ciphers: TKIP
WMM: * Parameter version 1
* BE: CW 15-1023, AIFSN 3
* BK: CW 15-1023, AIFSN 7
* VI: CW 7-15, AIFSN 2, TXOP 3008 usec
* VO: CW 3-7, AIFSN 2, TXOP 1504 usec
[/tt]
Re: Security: TG582n broadcasts serial number unprotected over wifi
02-07-2013 8:09 PM
02-07-2013 8:14 PM
02-07-2013 8:23 PM
02-07-2013 8:24 PM
If you disable WPS. does it still get broadcast?
02-07-2013 8:37 PM
Quote from: Anotherone Oh come on you can't be serious?
Absolutely serious!
Enlighten/educate me.
02-07-2013 8:44 PM
02-07-2013 8:47 PM
You could argue it doesn't matter because the serial number is broadcast on the LAN anyway. So if you hack the wifi password, you've got two ways to get the default admin password.
02-07-2013 8:49 PM
Update
Not sure my argument is now valid if its broadcast on the LAN anyway..
02-07-2013 9:01 PM
02-07-2013 9:10 PM
02-07-2013 9:19 PM
02-07-2013 11:22 PM
03-07-2013 6:15 AM
03-07-2013 9:02 AM
jump forward to 2013 and people newly aware are realising for the first time why the information (that does seem somewhat stupid to a lay person) has always stated you much change the password before using it...
