Sagemcom Router
FIXED- Subscribe to RSS Feed
- Sagemcom Router
17-08-2016 11:55 AM
Fixed! Go to the fix.
17-08-2016 1:19 PM
The lights flashing indicates something is transferring data across the network, if this is a lot of traffic (specifically upload) it can cause slowdowns.
It's worth changing the wifi password on your router and also try disconnecting each wireless devices one by one to see if that resolves the issue.
Re: Sagemcom Router
17-08-2016 5:20 PM
@Chris - Re. the 2704n router, is there any reason why I can't see all active devices on Wifi? Some are not showing at all. And as mentioned in a similar thread with the same router, the device name was showing as 'Joe Bloggs iPhone' but then changed to 'Unknown'.
Is there a fix to this?
Re: Sagemcom Router
17-08-2016 9:13 PM
