Safe Surf option
- Re: Safe Surf option
Safe Surf option
27-01-2008 8:17 PM
sorry but i have another question, I'm going through My Account area to familiarise my self with it and have come across a Set My Safe Surf option, from what i can gather it seems to be linked to Peer to Peer.
I'm not quite sure what this is but I think its something to do with large file downloads e.g. films and so on.
Am i correct ? and seeing as the only large downloads i do is via the Microsoft update site and so on can I safely disable it or will it be best to leave alone ?
Will it make any difference ?
regards
john
regards
john
Message 1 of 7
(2,075 Views)
6 REPLIES 6
27-01-2008 8:19 PM
This is mostly aimed at parents with kids - it blocks the p2p apps (emule, bittorrent etc) from running. If you don't use these then you can leave it off or on, it shouldn't make a difference and it won't affect any downloads from microsoft.
Hope that helps,
Hope that helps,
Message 2 of 7
(1,008 Views)
27-01-2008 8:25 PM
thanks, Thats what I call quick, I was just looking round the forum before closing down and noticed my question was answered, much appreciated.
regards
jono
regards
jono
Message 3 of 7
(1,008 Views)
27-01-2008 10:34 PM
Quote from: orbrey This is mostly aimed at parents with kids - it blocks the p2p apps (emule, bittorrent etc) from running...
But parents shouldn't rely on it - it's trivial to get most P2P apps to use non-standard ports.
Message 4 of 7
(1,008 Views)
27-01-2008 10:39 PM
Yep. In fact, really, the Safe Surf option is rather disappointing. This is what it blocks :-
I have safe surf switched on, yet VMBU is still showing a significant amount of P2P traffic.
Quote TCP 412 DirectConnect
TCP 1214 Kazaa
TCP 4661 - 4662 eDonkey
UDP 4665 -4666 eDonkey
TCP 5498 - 5501 Hotline
UDP 6257 WinMX
TCP 6699 WinMX
TCP 6346-6347 Gnutella
TCP 6881-6889 BitTorrent
TCP Port 119 Usenet
Message 5 of 7
(1,008 Views)
28-01-2008 12:55 AM
I thought safe Surf uses the Ellacoya classifications for P2P/Usenet etc, not just port number blocking.
Message 6 of 7
(1,008 Views)
28-01-2008 2:41 PM
Quote from: Peter I thought safe Surf uses the Ellacoya classifications for P2P/Usenet etc...
Even if it did it won't pick up on a lot of the encrypted P2P traffic - this seems to be classified as a mixture of P2P and "Other".
So far this month 53% of my traffic is described as "Other"
Message 7 of 7
(1,008 Views)
