SSH
- SSH
SSH
24-05-2010 8:24 PM
Hi, Can the Thomson router support cli via SSH? I know telnet works but can SSH be enabled? I know the router boasts SSH encryption but I can't fine how to enable the SSH in the CLI
Message 1 of 9
(1,642 Views)
8 REPLIES 8
Re: SSH
24-05-2010 8:43 PM
oops... misread the post so my reply was wrong so deleted.
Why Can't I delete my own posts mods?
Message 2 of 9
(801 Views)
Re: SSH
24-05-2010 8:57 PM
No Problem, Any ideas?
RA config?
Service System?
RA config?
Service System?
Message 3 of 9
(801 Views)
Re: SSH
24-05-2010 9:42 PM
Quote from: Peter oops... misread the post so my reply was wrong so deleted.
That would be a legacy from a rouge mod, during my time (no names). Just use the report facility asking for it to be deleted.
Message 4 of 9
(801 Views)
Re: SSH
25-05-2010 10:32 AM
Anyone? Help please. If it is a no then it is not a problem at least I will know.
Message 5 of 9
(801 Views)
Re: SSH
25-05-2010 12:33 PM
i don't think you can. telnet is all you get.
Message 6 of 9
(801 Views)
Re: SSH
25-05-2010 3:32 PM
The short answer is I'm not sure.
There's a CLI guide here which might help, but it's rather large.
Message 7 of 9
(801 Views)
Re: SSH
25-05-2010 4:51 PM
This 'ere TG585v7 doesn't show ssh in it's server list so I guess you can't. This may be version dependent as things do get removed/added in different versions due to limited space.
{mike}=>service system list
Idx Name Protocol SrcPort DstPort Group State
1 CWMP-C tcp disabled
2 CWMP-S tcp 51005 disabled
3 DHCP-S udp 49152 enabled
4 DNS-C udp 53 enabled
5 DNS-S udp 53 enabled
6 DYNAMIC_DNS enabled
7 FTP tcp 21 enabled
8 HTTP tcp 80 enabled
9 HTTPI tcp 8080 disabled
10 HTTPs tcp 443 enabled
11 IGMP-Proxy igmp enabled
12 IP_COMMANDS enabled
13 MDAP udp 3235 enabled
14 PING_RESPONDER icmp 8 enabled
15 PPTP enabled
16 SLA_ICMP_PING icmp 8 disabled
17 SLA_UDP_PING udp 7 disabled
18 SNTP udp 123 123 enabled
19 SSDP udp 1900 enabled
20 TELNET tcp 23 enabled
21 TFTP-C udp 69 disabled
Message 8 of 9
(801 Views)
Re: SSH
25-05-2010 5:32 PM
Hi All, Thanks for the input. I have checked with BT and Thomson and the answer is in fact no. The CLI is only accessable via Telnet, my workaround is HTTPS to the GUI.
Message 9 of 9
(801 Views)
