SSH in local network
- Re: SSH in local network
23-11-2012 4:12 PM
I have a standard PlusNet ADSL router with WiFi. I want to SSH between laptops in my local network, but it seems that the router blocks port 22. Are there any solution for that?
Best regards,
Dmitry
Best regards,
Dmitry
Message 1 of 7
(1,314 Views)
6 REPLIES 6
23-11-2012 4:14 PM
welcome to the forum
i doubt it's your router that's blocking it on your lan, no router I've ever owned has blocked anything internally.
possibly a firewall issue?
Message 2 of 7
(817 Views)
23-11-2012 5:36 PM
Some routers don't provide a 'NAT loopback' capability i.e. allow one internal device to access another internal device via the WAN IP address.
Of course, if you're attempting to connect using the LAN-side address directly then it's not this but I thought it worth the mention, particularly if you're using DNS and hence it have not been obvious which address was actually being attempted.
Mathew
Mathew
Message 3 of 7
(817 Views)
23-11-2012 5:54 PM
I ssh between my machines all the time, so not a problem (even when I used the supplied router).
As stated are you trying to get to a machine that is the dmz (i.e. via the external ip) or just between machines on the same subnet.
Things to check are that you can ping by name (if you are trying to ssh by name) and that the ssh server is accepting connections (ssh from itself to itself to check) you could also try a network scanner to see if a firewall is blocking it on the local pc's.
You don't say what os you are using so more help needs more info.
Message 4 of 7
(817 Views)
23-11-2012 7:35 PM
bound to be some flavour of *nix or bsd, 'doze I'd have thought, not much point installing an ssh server for a lan side ssh job..
Message 5 of 7
(817 Views)
24-11-2012 9:59 AM
Quote from: dvorak bound to be some flavour of *nix or bsd, 'doze
Well that covers all most everything current
I use ssh to my lt as I said as it is not easily accessible and runs as a "server" 24/7 and ssh +x tunnelling let me run gui apps.
Message 6 of 7
(817 Views)
24-11-2012 10:33 AM
Likewise I regularly run internal tasks over SSH - not for security but the fact that many functions are inherently designed to operate that way e.g. rsync backups over a remote shell thus not needing to run a daemon at the other end. Changing the standard model to use another method doesn't really achieve anything (other than unnecessary customisation).
Mathew
Mathew
Message 7 of 7
(817 Views)
