SPEED drop yet again grrr
- SPEED drop yet again grrr
- « Previous
- 1
- 2
- Next »
Re: SPEED drop yet again grrr
19-12-2010 6:59 PM
If you feel comfortable in telneting the router, so it connects on ADSL (992.1) insead of the current ADSL2 (992.3) it might improve things.
(Some info here)
http://community.plus.net/library/hardware/forcing-adsl-modulation-on-thomson-585v7/
(Some info here)
Message 16 of 17
(147 Views)
19-12-2010 10:22 PM
id save all the instructions first, so you can reverse it incase (for whatever reason) the router will not connect.
Looks like the phone isnt causing any issues, good and bad (means its not a simple fix )
possible for you to do the "if possible.." bit on my last post?
Regards
Regards
Message 17 of 17
(147 Views)
- « Previous
- 1
- 2
- Next »
