SNR slowly drops
- Re: SNR slowly drops
SNR slowly drops
08-08-2011 8:38 PM
Previously my SNR dropped in the evening and then rose in the morning as I'm on an overhead cable but this recent behaviour is very odd.
08-08-2011 8:53 PM
08-08-2011 8:54 PM
08-08-2011 9:14 PM
08-08-2011 9:20 PM
If the connection doesnt drop, dont worry about it?
Regards
08-08-2011 9:22 PM
08-08-2011 9:29 PM
Regards
09-08-2011 12:05 AM
09-08-2011 8:11 AM
Not that it means much to me 😉
09-08-2011 9:32 AM
09-08-2011 9:40 AM
I only powered routerstats up this morning
09-08-2011 9:58 AM
However bit swapping is clearly working.
If it continues throughout the day and doesn't settle down then you just have a line with a bit of random noise on it
Do you want to remove your IP address from the picture
09-08-2011 10:04 AM
The SNR has risen slightly this morning to 4
Speedtest shows this:
09-08-2011 10:11 AM
You could do a resync and see what happens.
If you want to monitor over night you would need to keep the PC running
09-08-2011 10:27 AM
Maximum Bandwidth (Up/Down) [kbps/kbps]: 908 / 5,280
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,088
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 440.00
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 29.0 / 48.5
SN Margin (Up/Down) [dB]: 22.0 / 6.5
Routerstats running and I'll leave my computer running for the next day or so
As for the speedtest result - its very odd : I usually get 3.7
