SNR reset also required
- SNR reset also required
23-01-2012 3:33 PM
I find it strange that it just jumped from 6 to 12db, and has stayed that way.
Could some kind soul at plusnet please reset that stupid DLM ?
Thanks,
Paul.
Re: SNR reset also required
23-01-2012 3:45 PM
23-01-2012 4:41 PM
There will have been a reason for the change. Are you using any extension cables/sockets?
Jojo
23-01-2012 6:42 PM
I have a xte2005 faceplate on the master box, with one extension from to the loft that is filtered by the faceplate.
The router is fitted to the faceplate on a 50cm lead.
It has been this way for 16 months + .
The loss of sync and raised snr from 6 to 12db came out of the blue.
Before and after this event the line remained stable, please look at the logs you have.
BTW some weeks ago bt had a fault at our exchange that affects quite a few people, when i managed to phone the faults number, i had a automated response saying they knew about a fault and were dealing with it !
Plusnet checked and could not find any info on this, at the time !
Could you please reset the snr for me ?
Thanks,
Paul.
24-01-2012 11:08 AM
Ok, I'll give it a go. Hopefully it will do the trick. If it does go up again, you may have to consider looking into your internal set up.
Jojo
24-01-2012 1:42 PM
Just wondering, how long does it take for the reset to happen ?
Also do i need to retrain the router manually or does the reset your end invoke a router reset here ?
Thanks,
Paul.
24-01-2012 1:51 PM
You won't have to reset, it'll be done from their end. It can take up to 24 hours but can happen a lot sooner.
Jojo
26-01-2012 2:17 PM
My snr is still at 12db.
Paul.
27-01-2012 10:15 AM
27-01-2012 2:48 PM
The reset has now happened this morning, snr now back at 6db.
Thanks,
Paul.
27-01-2012 2:51 PM
27-01-2012 4:51 PM
I assume the snr reset has started a 10 day training period, will the profile be updated your end over the next day or two, or will it be updated after 10 days ?
Thanks,
Paul.
27-01-2012 5:10 PM
