SNR is high
- SNR is high
SNR is high
28-11-2014 1:30 PM
I've recently removed the bell wire from my extensions and managed to get an extra 1Mb out of the ADSL connection (2.5Mb to 3.5Mb) however my SNR is at 15Db.
Is this too high and could it be reduced to improve speeds further? Attenuation is 46 if that also helps?
Message 1 of 4
(620 Views)
3 REPLIES 3
Re: SNR is high
28-11-2014 1:46 PM
Hi Jamie,
I can see your connection has remained fairly stable recently so we can give an SNR reset a try for you.
I've submitted that now so you should see if that's made any difference over the next 24 hours.
Message 2 of 4
(443 Views)
Re: SNR is high
28-11-2014 1:52 PM
Great thats jumped to 6.5Mb with an SNR of 6Db
Message 3 of 4
(443 Views)
Re: SNR is high
28-11-2014 4:11 PM
Message 4 of 4
(443 Views)
