SNR Reset needed?? -- update
- SNR Reset needed?? -- update
- « Previous
- Next »
Re: SNR Reset needed?? (Annoyed now!!!)
01-05-2013 8:39 PM
Yep, already done. When I visted a couple of weeks ago, Both the Master and extension had wires to terminals 2,3,4,5. Removed and trimmed the wires going to 3 and 4 on both Master and extension.
See piccie below of current wiring status. Would the cut off extension be causing an issue. I didnt remove it, as I wasnt sure if I should be playing inside the green box, but I will if it wouldnt cause an issue. Failing that, I cant see how I can get the wiring any better. The flat phone extension used for their telephone, is filtered at the master, could this be an issue?
I would welcome any advice as to what if anything can be improved further....
01-05-2013 10:38 PM
As you may recall from your posting about this last August, the flat phone extension shouldn't be a problem if it's filtered at the master.
The cut off extension might be an issue. There will be no record of it on OR records, so I'd get rid of it all together.
Log into the modem/router and drop the PPP session and then after about a minute power down the modem/router. Then you can open up the green box and remove it altogether. Whilst you are there just make sure that only the Blue/white and White/blue wires are connected to the incoming line and any orange wires are not connected to anything or each other. Remove from any terminal, cut off any bare ends, and coil them up if need be - did I say open the box ...... who's to know
02-05-2013 8:22 PM
Quote from: Anotherone If you are using Windows 7, you may find http://social.technet.microsoft.com/wiki/contents/articles/910.how-to-enable-telnet-client-in-window... useful.
As you may recall from your posting about this last August, the flat phone extension shouldn't be a problem if it's filtered at the extension
Ahhhhh will try that, thanks.. I will have a look inside the green box, and try to tidy up the wiring a little more. Think they may need a 'noisy line' fault to get them a modern nte5 master
Forgot about last aug, its taken this long to organise things will let you know if things improve. They have gone away again, so cant get back till next weekend.
11-05-2013 4:59 PM
11-05-2013 5:47 PM
PS. Are you still annoyed now?
11-05-2013 8:29 PM
No not annoyed now, even though his snrm is at 3db, as is mine still. I removed all extraneous wiring, and all orange wires still connected. Lets hope it all remains stable, and his profile dosnt take too long to catch up...
13-05-2013 11:45 AM
Re: SNR Reset needed?? -- update
02-06-2013 8:11 PM
04-06-2013 11:24 AM
The information as requested:
BT Profile 2954
PN profile 3100
Target SNR up to 6dB as of 31st May
Radius for last 7 days:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13703411326436.png"/>
Copper Line Check Test Outcome :
Test Outcome
: Pass
Proposed Repair Actions
: Not Applicable
Additional Text
: CIDT LINE TEST OK - ALL SOCKETS UNPLUGGED
04-06-2013 12:09 PM
- « Previous
- Next »
