SMPT problems using Outlook 2003
- SMPT problems using Outlook 2003
- « Previous
- 1
- 2
- Next »
Re: SMPT problems using Outlook 2003
17-01-2010 12:41 PM
Quote from: jelv Have you tried with all spyware/firewall/anti-virus disabled?
I don't get this at all. Ok it was ( I think) Spyware Terminator updater that was causing my problem but I haven't changed anything & have been running that programme for about 18 months without a problem. It still does its auto updates but email has been fine ever since.
Message 16 of 18
(253 Views)
17-01-2010 12:55 PM
Quote from: JudyB
Yes, I just tried that and got the same behaviour.
OK, after more investigation here, it seems that Norton is the culprit. For the record, with Norton Antivirus 2009, clicking "Disable AntiVirus Auto-Protect" doesn't turn off everything. In particular it obviously does NOT disable the email scanning.
After specifically turning off the email scanning I can successfully telnet and send/receive email.
My guess is that an update sometime yesterday to Norton succeeded in blocking all email >:(.
Since I know that NAV email scanning will catch infected emails (if PlusNet misses them for any reason) I prefer to have this on, so it looks like my next port of call is the Norton support website...
Thanks for your help in diagnosing this.
Message 17 of 18
(253 Views)
17-01-2010 5:44 PM
this thread is getting horribly mixed up, two or more people answer the same question for who?
Message 18 of 18
(253 Views)
- « Previous
- 1
- 2
- Next »
