Routing issue[Solved]
- Re: Routing issue
21-08-2010 6:44 PM
Im having trouble viewing slashdot.org . It appears that Im unable to communicate with a.fsdn.com which is used by the site. when running a traceroute for the a.fsdn.com I get the following:
traceroute to e872.g.akamaiedge.net (88.221.179.172), 30 hops max, 38 byte packets
1 lo0-central2.pcl-ag04.plus.net (195.166.128.242) 10.000 ms 20.000 ms 20.000 ms
2 gi1-12-421.pcl-gw01.plus.net (84.92.6.232) 10.000 ms 10.000 ms 10.000 ms
3 te2-2.pte-gw1.plus.net (212.159.0.186) 10.000 ms 20.000 ms 10.000 ms
4 te2-4.pte-gw2.plus.net (212.159.1.102) 10.000 ms 10.000 ms 10.000 ms
5 te3-2.ptn-gw02.plus.net (212.159.1.105) 10.000 ms 20.000 ms 10.000 ms
6 195.66.226.168 (195.66.226.168) 10.000 ms 10.000 ms 10.000 ms
7 * * *
I am able to browse the site via my mobile phone, so I think the site must be ok. Any ideas?
Kihon
7 * * *
Kihon
Message 1 of 5
(1,107 Views)
4 REPLIES 4
Re: Routing issue
21-08-2010 8:50 PM
It loads OK for me !
What DNS settings are you using ?
Message 2 of 5
(399 Views)
Re: Routing issue
21-08-2010 10:10 PM
> tracert a.fsdn.com
Tracing route to e872.g.akamaiedge.net [92.123.83.172]
over a maximum of 30 hops:
1 2 ms 2 ms 2 ms My_ADSL_Gateway [192.168.xxx.xxx]
2 15 ms 14 ms 15 ms lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 13 ms 14 ms 14 ms gi1-6-705.pcl-gw02.plus.net [84.92.0.188]
4 14 ms 14 ms 14 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 16 ms 15 ms 16 ms te2-4.pte-gw2.plus.net [212.159.1.102]
6 14 ms 14 ms 14 ms linxnap.netarch.akamai.com [195.66.224.168]
7 15 ms 14 ms 14 ms a92-123-83-172.deploy.akamaitechnologies.com [92.123.83.172]
Trace complete.
Trace complete.
Message 3 of 5
(399 Views)
Re: Routing issue
21-08-2010 10:25 PM
> pathping a.fsdn.com
0 My_PC [192.168.xxx.xxx]
1 My_ADSL_Gateway [192.168.xxx.xxx]
2 lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 gi1-6-705.pcl-gw02.plus.net [84.92.0.188]
4 te2-2.pte-gw1.plus.net [212.159.0.186]
5 te2-4.pte-gw2.plus.net [212.159.1.102]
6 linxnap.netarch.akamai.com [195.66.224.168]
7 a92-123-83-172.deploy.akamaitechnologies.com [92.123.83.172]
Computing statistics for 175 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
1 2ms 0/ 100 = 0% 0/ 100 = 0% My_ADSL_Gateway [192.168.xxx.xxx]
2 18ms 0/ 100 = 0% 0/ 100 = 0% lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 22ms 0/ 100 = 0% 0/ 100 = 0% gi1-6-705.pcl-gw02.plus.net [84.92.0.188]
4 25ms 0/ 100 = 0% 0/ 100 = 0% te2-2.pte-gw1.plus.net [212.159.0.186]
5 20ms 0/ 100 = 0% 0/ 100 = 0% te2-4.pte-gw2.plus.net [212.159.1.102]
6 15ms 0/ 100 = 0% 0/ 100 = 0% linxnap.netarch.akamai.com [195.66.224.168]
7 15ms 0/ 100 = 0% 0/ 100 = 0% a92-123-83-172.deploy.akamaitechnologies.com [92.123.83.172]
Trace complete.
Trace complete.
Message 4 of 5
(399 Views)
Re: Routing issue
21-08-2010 10:42 PM
Found the issue - my router is blocking the site for some reason (not configured to block it, it just decided to). Tried a different router, and everything works.
Thanks anyway.
Kihon
Thanks anyway.
Kihon
Message 5 of 5
(399 Views)
