Router with a specific chipset
- Router with a specific chipset
29-01-2010 7:23 PM
Currently have a Netgear DG834GT with the broadcom chipset in and just discovered my DSLAM has the Texas Instruments Chipset. Would I see any difference in using a router with matching chipset ? what ADSL2+ routers have a Texas Chipset ?
Message 1 of 4
(989 Views)
3 REPLIES 3
Re: Router with a specific chipset
29-01-2010 11:05 PM
I wouldn't expect a big difference in performance I think, Netgear is a good router as long as you have the latest firmware. if your on ADSL2+ this means that INP is likely to be on for your line and will put some overhead on your router to get some calculations done so the latests firmware will ensure that your router is handling the INP calculations in a timely manner.
btw, almost all Edimax routers have TI chipsets
Message 2 of 4
(377 Views)
30-01-2010 9:41 AM
The Broadcom chipset only has an advantage on SOME LLU ADSL2+services.
I know that on Be for example their DSLAM's implement an extension to INP that works with Broadcom but not other chipsets to further improve performance and stability. But they supply your router anyway, though many choose to use their own so do take note of this.
(DG834GT is very popular with Be customers)
Message 3 of 4
(377 Views)
12-02-2010 7:01 PM
How is the Trendchip for ADSL2+ ?
Any well known issues with certain new 21CN dslams ?
(Like the Broadcom BCM6348 & Huawei hardware which don't seem to get on well....)
Thanks f9o
Thanks f9o
Message 4 of 4
(377 Views)
