Router settings/ login/ broadband speed
- Re: Router settings/ login/ broadband speed
21-08-2016 11:04 PM
And another issue I have is i cant login into my router using the admin/ router password...? I'm using ip 192.168.1.254 to try and change my wifi password but won't accept the password. Very unhappy at the moment after the switch thinking of cancelling the whole thing and I also paid upfront 12 months in advance. Sky was easier to setup not a single problem with sky apart from the rising costs of its broadband service... Please help Plus.net..... Thanks, Steve
on 21-08-2016 11:30 PM - last edited on 22-08-2016 10:41 AM by Mav
Hi and welcome, are you entering the router password all in upper case
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules
21-08-2016 11:31 PM
Just replied but cannot see it here
22-08-2016 1:07 PM
22-08-2016 6:09 PM
22-08-2016 8:37 PM
It might be best to factory reset your Plusnet router. Instructions are given here, just click on the picture of the router you were supplied with and follow the help text given https://www.plus.net/help/broadband/router-user-guides/
