Router reset button
oakwoods
Router reset button
I have just replaced a BT Home Hub 5 modem/router with a better Asus router. I shall now sell the Home Hub but I forgot to remove the SSID and passwords. There is a reset button on the router for taking it back to factory settings. My question is - if I power up the Home Hub without connecting it to my network, will the reset button revert the router back to the original SSID and passwords that are printed on the router? I need to ensure whoever buys it can login to it.
I don't want to connect it to my computer now in case it messes with my network.
6 REPLIES 6
198kHz
Fixes: 17
Re: Router reset button
The reset button will work whether on a network or not.
The principle thing is that it's held in until 'something' happens.
The lights will change, flash, or go out - something will happen - you'll know it when you see it.  Smiley
In my experience it always takes longer than expected.  Wink
To err is human, but to really foul things up requires an algorithm.
oakwoods
Thanks for that but what I need to know is will the router revert back to the original SSID and password printed on the case.
You can probably check - power it up and see if it's back to the original SSID (is printed on the back?).
198kHz
Fixes: 17
According to BT,
Resetting a BT Home Hub to factory settings takes the Hub right back to how it was when you first got it. It will overwrite any changes you might have made since.
Instructions
oakwoods
Thanks for the replies. I will do the reset but I can't see if it has reverted to the original SSID without connecting to the network, which is what I am trying to avoid. I shall reset and hope it reverts to what is printed.
TORPC
when returning to factory settings, all settings / SSID's will have to be reset
