Router reporting G.992 instead of G.992.5
- Router reporting G.992 instead of G.992.5
- « Previous
- 1
- 2
- Next »
Re: Router reporting G.992 instead of G.992.5
19-12-2012 6:37 PM
Should I try the test socket again or should I leave it till tomorrow?
Edit: Also, I collected some info yesterday, my BT line profile is 6.3 Mbps. Why is it different to the one I'm seeing in router stats? This is the info:
Router Stats
Uptime: 0 days, 0:11:21
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,136
Data Transferred (Sent/Received) [MB/MB]: 4.27 / 31.92
Output Power (Up/Down) [dBm]: 11.7 / 19.9
Line Attenuation (Up/Down) [dB]: 13.0 / 22.5
SN Margin (Up/Down) [dB]: 30.0 / 6.0
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): - / 1 / 0
BT Speed Test
Download speed achieved during the test was - 4.12 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.3 Mbps
Upload speed achieved during the test was - 0.36Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Exchange Information
Exchange: Radyr BT Code: SWRRY
Distance:- Direct: 574 metres
(appx)* By Road: 2.4 km
Status
ADSL enabled: July 6, 2004
DSL Max enabled: November 30, 2005
21CN WBC (Broadband) Enabled
21CN due : (PSTN) info N/A
FTTC Not available
SDSL enabled : Not Enabled
Broadband Access† Market 2
BTw Pricing Band Band E
BT Line Speed Estimation
Fixed ADSL: 2048 kbps (2 Mb)
DSL Max: 6500 kbps (6.5 Mb)
21CN WBC : 12000 kbps (12 Mb)
Random side note for Chris, any PN guys or anyone that knows, now that unlimited it out, it's around £1.50 cheaper than the Extra package my parents are on. If they switch to unlimited, will the service be exactly the same?
19-12-2012 6:44 PM
19-12-2012 7:02 PM
Quote from: aj007 I collected some info yesterday, my BT line profile is 6.3 Mbps. Why is it different to the one I'm seeing in router stats? This is the info:
Router Stats
BT Speed Test
Because the IP Profile is always 88.2% of the bandwidth figure on your type of connection. Nothing to worry about.
As has just been said, just leave things now until you expect to be on ADSL2+ :). These stats will indeed be useful for comparison.
19-12-2012 7:08 PM
Better! There won't be any speed restriction on all the P2P stuff they do .... ROFL!
Quote from: aj007 Random side note for Chris, any PN guys or anyone that knows, now that unlimited it out, it's around £1.50 cheaper than the Extra package my parents are on. If they switch to unlimited, will the service be exactly the same?
It's a free upgrade, but it does start a new 12-month minimum term.
20-12-2012 1:28 PM
Uptime: 0 days, 8:31:33
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,211 / 11,147
Data Transferred (Sent/Received) [MB/MB]: 35.97 / 634.15
Output Power (Up/Down) [dBm]: 11.9 / 0.0
Line Attenuation (Up/Down) [dB]: 12.4 / 25.5
SN Margin (Up/Down) [dB]: 6.5 / 6.7
Error Seconds (Local/Remote): 224 / 0
CRC Errors (Up/Down): 71 / 324
HEC Errors (Up/Down): 58 / 852
BT Speedtester
Download speed achieved during the test was - 5.71 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 9.83 Mbps
Upload speed achieved during the test was - 1.01Mbps
Upstream Rate IP profile on your line is - 0.83 Mbps
But I'm still not seeing an real increase in download speed, it's around 6mbps or 700kb/s on Steam...
20-12-2012 1:54 PM
Your sync is still a bit low for the reported attenuation , are you still in the test socket ? and are there any extension sockets still live when you use the test socket ?
20-12-2012 2:03 PM
Plusnet is reporting my current and estimated line speed at 6mb. So I guess it hasn't caught up?
Edit: Also, not sure if this is relevant but my mum said that initially, when they emailed here the estimate, it was 4.5mb. What's up with that?
20-12-2012 5:18 PM
21-12-2012 5:44 PM
It did make a bit of a difference in the test socket, here are the router stats:
Stats
Uptime: 0 days, 0:10:07
Bandwidth (Up/Down) [kbps/kbps]: 1.159 / 12.404
Data Transferred (Sent/Received) [MB/MB]: 2,62 / 24,05
Output Power (Up/Down) [dBm]: 12,3 / 0,0
Line Attenuation (Up/Down) [dB]: 12,1 / 25,0
SN Margin (Up/Down) [dB]: 6,2 / 6,5
Error Seconds (Local/Remote): 12 / 0
CRC Errors (Up/Down): 0 / 13
HEC Errors (Up/Down): 0 / 55
BT Speedtester
Download speedachieved during the test was - 10.33 Mbps
IP Profile for your line is - 10.94 Mbps
Upload speed achieved during the test was - 0.93Mbps
Speedtest.net
Download - 10.75mbps
Upload - 0.97mbps
Ping - 24ms
It's running much better now! Any more profile tweaks to squeeze some more performance out or is this where it is? Regardless, I'm pretty happy about sorting this out and the great response, thanks so much for all the help!
21-12-2012 6:26 PM
However as has been said, you shoudl be getting more than 12,404kbps badwidth/sync. A lot more!
On 25dB attenuation I would expect most lines to be on at least 16Mbps and good ones possibly around 18Mbps.
Edit - I made a typo there - "badwidth". Smart - I'll leave it in the circs.
21-12-2012 7:06 PM
21-12-2012 7:10 PM
21-12-2012 11:58 PM
Router stats
Uptime: 0 days, 5:01:55
Bandwidth (Up/Down) [kbps/kbps]: 1.208 / 12.647
Data Transferred (Sent/Received) [MB/MB]: 35,11 / 723,40
Output Power (Up/Down) [dBm]: 12,2 / 0,0
Line Attenuation (Up/Down) [dB]: 12,3 / 25,5
SN Margin (Up/Down) [dB]: 6,1 / 5,8
Error Seconds (Local/Remote): 384 / 0
CRC Errors (Up/Down): 14 / 742
HEC Errors (Up/Down): 8 / 5.783
BT Speedtester
Download speed achieved during the test was - 9.05 Mbps
IP Profile for your line is - 11.16 Mbps
Upload speed achieved during the test was - 1Mbps
Speedtest.net
Download - 10.48 mbps
Upload - 1.03 mbps
Ping - 19ms
I'm a little surprised that the stats are this similar, but it is what it is I guess!
24-12-2012 7:51 PM
Was just wondering if anything else can be done to improve my speed? I think Estragon was right, isn't my sync speed a little low given the attenuation?
- « Previous
- 1
- 2
- Next »
