Router refusing to accept wifi password on new phone
i have a sony xperia L3, it connects to all wifi except my plusnet home wifi.
I have done all the usual reset networks, forget network, re-started router.
It just says 'check password and try again'... I am typing in the correct password, have had someone check it  and its all definitely correct.  it is driving me mad.
I am reliably told its the router to blame.  all other devices connect up just fine including ipads, other mobiles, desktop pcs, laptops etc....
Any help greatly appreciated.
6 REPLIES 6
Fixes: 51
Re: Router refusing to accept wifi password on new phone
@MDTD
If all other devices connect without a problem, I can't quite see how the router can be to blame?
Strangely enough someone else has a phone (in this case an iPhone 7) that won't connect to their home network.
My suggestion - if it is possible - can you try connecting to say an amenable neighbours network?
Fixes: 163
Have you checked that you are using the correct security protocol, probably WPA2, on your phone?
Thanks Baldrick1, where would that setting be on my phone?
Fixes: 163
@MDTD
This is extracted from here: https://support.sonymobile.com/gb/xperial3/userguide/wi-fi/
I assume that it is in the Security field.
i think i found it, pressed the wps button on router and it has connected.
thank you
Fixes: 163
Ah, fair enough.
