Router random resets and DLM
- Router random resets and DLM
- « Previous
- Next »
Re: Router random resets and DLM
22-12-2013 1:14 PM
22-12-2013 2:51 PM
Still a lot lower throughput compared to sync but much better than my previous post today.
23-12-2013 10:14 AM
This morning I ran a speed test after taking those stats, note the low throughput compared to the line speed:
then shortly after that it drops the connection and resyncs:
And now the connection is dropping all the time again....
24-12-2013 9:38 AM
Why is the cooling off period ten days when the dlm period is ten days? Basically you get penalized for sitting tight and allowing the line the benefit of time to stabilize thus also using your cooling off period. Is one supposed to be psychic?
24-12-2013 4:05 PM
It might be worth trying to determine if the drops only occur at particular times of the day - it's possible your broadband is being adversely affected by interference from some electrical device nearby (REIN), and the BT engineer wouldn't have been able to find any problem if the source of the REIN wasn't on at the time they visited. You might need to monitor the stats with software like RouterStats, as the sync speed being reduced to 4543k might workaround the line dropping.
26-12-2013 9:59 AM
That would be the mystery of my migration at work, stable line with sky fttc (40mb/ got 38) up to the transfer on 19/11/13 to plusnet and now this from day one. Completely miffed and confused, maybe someone put their Christmas lights up early!
26-12-2013 10:05 AM
The results from FTTC are not relevant
Why did you change from FTTC to ADSL
26-12-2013 11:11 AM
28-12-2013 12:44 PM
29-12-2013 10:04 AM
The ip profile was still around 4mb but I was able to stay synced at that speed and had no disconnections (I would have noticed seen as I was on xbox live approx 7pm-12pm), progress I thought!
However today my speed test results are abysmal:
29-12-2013 1:21 PM
02-01-2014 10:25 PM
1gb file test from thinkbroadband.co.uk:
03-01-2014 10:46 AM
07-01-2014 3:03 PM
And this is the tap 3 test:
These are the router stats:
- « Previous
- Next »
