Router random resets and DLM
- Router random resets and DLM
26-11-2013 5:20 PM
I think dlm has capped my line down speed due to the fact the tg852n I was supplied seems to like to randomly reboot itself several times a day. Over the weekemd I was syncing at approx 9500 down and today i'm now down to:
Would someone from support mind having a look at the profile please? I think I've sorted the router reset issue by using the 10.2.2.B firmware from plusnet, no reboots in the past 24hrs that I've noticed.
Re: Router random resets and DLM
26-11-2013 7:41 PM
27-11-2013 10:18 AM
Today's stats and its definitely looking like I've been capped.
27-11-2013 11:47 AM
we'll need to focus on preventing the disconnection in order for the speeds to improve.
I'll reply to ticket 77779816 for you regarding the router.
Here's a view of the disconnections we've logged over the past week in case that helps.
<img src="http://community.plus.net/visualradius/generated/image13855526728046.png"/>
27-11-2013 12:04 PM
Thanks for the reply. The router hasn't rebooted itself since I updated the firmware Monday afternoon, prior to that it was doing a full hard reset where it was reloading the kernel according to the log and my pc lan port was reporting no lan connection available at those times. The reset on Tuesday was me trying to resync at a higher rate and again one of the two resets today were me restarting the gateway in an attempt to resync at a higher rate, that was approx 10am ish, however I don't recall rebooting it at approx 12.30am as the graph shows.
Thanks,
David.
28-11-2013 10:30 AM
28-11-2013 10:42 AM
Cheers for the update here's how the connections are looking over the past 7 days, I'll reply to your ticket shortly:
<img src="http://community.plus.net/visualradius/generated/image13856353215913.png"/>
28-11-2013 10:49 AM
Thanks for th reply. Would it be possible to get my snr reset so I can get back up to the higher speed please?
Thanks.
28-11-2013 12:29 PM
28-11-2013 5:21 PM
29-11-2013 10:34 AM
29-11-2013 11:56 AM
30-11-2013 3:33 PM
What I find most baffling though is the fact I still appear to have sky broadband active on my line. I was trying to turn the old sky router into an access point but in my haste connected the dsl as well as the rj45 from the pc and voila!
That can't be normal can it?
30-11-2013 10:50 PM
01-12-2013 1:30 AM
What value is set for Current line speed in your Plusnet Member Centre? For the sync speed of 6515kbps in your TG582n routerstats table Current line speed should have been 5.7Mbps but I suspect yours is/was around 4.2Mbps judging by the speed test result. Current line speed should update to match BT's IP Profile when new values are passed on.
